Why I rescue ladies models
diveboy
This is the 14k gold Model 877 with 15 jewels and originally sold for $110.
Heres how it arrived - yes thats lead solder on the bottom right... sure you've see it all before but for me, first time but I couldn't let that stop me buying it.
Zj6LF5opNCWTbE6mtAga2wZ6Dc8hdPX7aQZnRVi0
I had a gold smith clean up the case and remove the lugs from another case and then went and saw a laser welder who attached the replacement lugs, I did the dial swap and case polish, then sewed up the ribbon band and the end result
zBw3fhR-mcGNTzOC5UvW3hETBh4Ty9t8nc7Ho_Vf
its currently 87 years old and hopefully will last another 87 years.
  • Like 5
It won't work!  Me wife steals my Lord Elgins all the time.  Rarely does she wear a ladies deco period watch and she's a deco nut, she loves them but they are too small for everyday wear.  That's a bonus for me as I restore them and don't have to worry about day to day wear.
Here's the model 103 Madame Premet from the Parisienne line,  again,  restored from bare cases and the matching ribbons and clasps is how they would have been in store when they went on sale in 1928
ZyZMZ6-dZDxXPG-HyZWPYW3AKHNYiGKX5CVYrgQd
After my first I swore I'd never work on a women's watch movement again (too small).  You can't beat the prices though.  I bought a Seiko Hi-Beat automatic with day & date for $9 and an eighty year old Rolex for $45.  They clean up just as nice as a men's watch although the resale value may not be as good.  They do make good gifts though.
Fantastic!
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
