Hi from the stormy Lowlands
Watchtime
Hi all,
Collecting watches for many years, mostly mechanical, I got triggered by the amazing technical knowhow of watchmovements by a close friend of mine some time ago. Not being troubled by any technical knowledge or education:), I had the opportunity of visiting my friends workshop and from that moment on I was hooked. I recently was able to buy the heritage of a watchmaker who passed away and I am now trying to sort out all the tools, parts, machines and other stuff so I can set up and complete a humble watchmakers workplace of my own. I was looking for  online co**BLEEP**s and noticed that there is no such thing in my area. Just before committing myself to the Timezone co**BLEEP**, I came accross WRT and the deal was done. What pleasantly surprised me was the friendliness and openness among the members and sharing solutions for encountered problems...I hope to learn as I consider myself as a newbee and contribute to this forum. Cheers from the Lowlands.
Hello from me. I was also very lucky after serving my apprenticeship and then my improving I was given a complete workshop not only for watches but lots of machinery for clock making. I never had to add a great deal. You will have a great time sorting all that you have out. How about posting up some pictures for as all to look at. Look forward to your input.
Goodmorning and thanks for the warm welcome. I spend a good part of the sunday to unpack the boxes and on request of oldhippy I made a few photos. I apologise for the poor quality as I made the pics with my phone. In the boxes, I found a lot of very nice items like a Bergeon caseback opener, a winder, a Witschi watchexpert(hope it still is in working order), crystal press, a huge load of tools and parts, springs, crystals, crowns, stems ect ect. I really like the old frames with the ETA parts in it. Enjoy.....
Here a few better pics of sorting the massive amount of items......the watchmakers bench is still in my storageroom, I first have to clear some space in my office for it. Most of the parts are unsorted so I started out with the sorted items and put all the rest in boxes again for checking at a later time, sorted on subject. It is a lot of fun to do......:)
Edited by Watchtime
Wow what an incredible amount of stuff to go through. Its going to take months to sort out. The photos are fine and clear. Thanks for sharing. If you find anything your not sure of just post a picture and I'm sure many on here will be able to help you out.
Welcome watchtime! Very good beginning! Most, if not all, of the tooling is already there I guess so now, with that hurdle covered, it is time to put them to the test! Good luck and please, ask away if you get stuck with any of those and/or derived projects.
Welcome fellow newcomer... I had a lot of stuff to go through, too.  I'm still going through it.  I bought my father's tools when he retired.  It was like Christmas going through all that.  I'm finally setting up a little work space to start using some of it.  Exciting, isn't it?
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
