Hi,
I just bought a Reina or Reima Swiss made watch cleaning machine (see photo's). Beside the brand name, there are two more names visible: Golay - Buchel & Cie Lausanne Suisse and Werner Schilter Machine bau, Kriens-Sweiz (probably the company who made this machine). If have number 623 and it works completely mechanical. By pumping the fluids from different compartments below to the top camber the watch parts are washed. A metal knob turns when the washing program is running and some metal pins will switch to a different part of the watching program. I don't have an instruction manual.
Can anybody tell me more about this watch cleaning machine?
Does someone have an instruction manual?
Thank you for your help, Jacob
Very nice looking machine! I'd imagine though that all the pumping of liquids is going to cause a lot more contamination of fluids, since you can never get all the liquid out of the main chamber by just pumping..
2 hours ago, Geo said:
I don't think it is designed fir cleaning watch parts.  The company on the name plate specialises in supplying pearls and gemstones to the jewellery industry.  I suspect the machine may be designed for cleaning the above.
have a read of this. http://listofcompanies.co.in/2012/01/16/golay-buchel-holding-sa/
That might be why I've never heard of it. I wasn't into gemology.
Golay - Buchel & Cie Lausanne Suisse  registered the "Favorite" trademark for watchmakers tools in 1939 and manufactured a full range of tools for the watchmaker with there catalogue running at over 300 pages many on this site will own and use Favorite tools.
Thanks for responding.@teegee on the bottom of the top chamber is a valve, this valve select a new liquid to fill and emptying the top chamber. See picture.
Every flask has its own tubing so hardly any cross contamination will happen.
Verzonden vanaf mijn iPhone met Tapatalk
@geo I'm convinced that this machine is specially designed to clean watches. It shows in the way the basket is mounted and the special designed baskets.6bd94a0ca8b64cf188161a25314fb9f7.jpg05d22b788b20926d844fe64b8b297003.jpg
I think your assumption that it is a watch cleaning machine is correct it looks to be a similar type of machine to a Bulova VC-10 watch cleaning machine.
 The information on the company was found at the following site,
http://www.mikrolisk.de/show.php?site=280&suchwort=Golay&searchWhere=all
They where once a very big company in the manufacture of watch tools but seem to have been restructed, in the 1980's and now as Geo has already stated they did supplie gem stones to the watch industry and pearls to the jewellery trade, I think they still had headquarters at Lausanne until recently.
They have been bought out a number of times and it appears they may have been dissolved as a company in Switerland this year,
https://www.moneyhouse.ch/en/company/golay-buchel-et-cie-s-a-12282108651
The catalogue for the full range of watch tools they used to make can be bought from the following site,
www.lathes.co.uk  but costs £130.00.
The machine I suspect will have been made in very small quanties and been very expensive judging from the quality of build so I dont think you will find much info on it.
Still it seems like it uses a lot of fluids and complications, making it awkward and unpractical for hobbyist's use.
The amount of fluids is the same as used in for example a Elma. I agree that it has more complications, however I love complicated things that's why I'm working with watches.
It does indeed look like it is for cleaning movement parts.  Like you I just love the engineering in it! :)
  • Similar Content
    • Hello Gentleman, Anyone ever work on this watch before? I've been enjoying this hobby for a while now and have had some decent results.  Am progressing nicely to more and more complicated movements,  but man, for the life of me, I can not figure out how to remove this ETA 7750 from the ring around it.  I've successfully removed the movement and its holder from its outer carbon fiber case, but cannot remove it further. I've removed both pushers and the stem and it, frustratingly,  doesn't simply drop out when inverted.  It also doesn't rotate from side to side within the outer movement holder.. it is stuck fast.   I'm a little embarrassed honestly.   The red arrow points to a line in the movement holder, but it is seemingly one piece and not separable there. I guess they just needed to reduce some outer diameter there. The ends of the minute and chronograph hand extend over the minute marking ring so would that mean that that minute marking ring is part of the dial attached to the movement? I guess I'm asking where does the dial end? Any point in the right direction would be most welcome. I've never worked on this movement before and I am chomping at the bit to do so.  It represents the next challenge in my progression. But obviously cant start until I remove it safely and I'm stumped!
    • Donor movement received. Now waiting for a proper & calm time slot to perform the transplant.
    • Hi Joe, I mean the situation when the escapement can be unlocked when pallet fork is pressed as the guard pin to touch the guard roller. This will be possible if the guard pin is short or the depthing of the escapement is not deep enough. The pallet fork was replaced, but I don't think it was adjusted to work correctly with this movement.  Of course, if there is defect on the guard roller, it also can lead to such problem.
    • Hi everyone, I am new to watch repair and loving the whole process, even some of my fails…maybe. Right now I am looking at purchasing a press for fitting watch crystals, and I was wondering if any of you have had experience with the BMC model (seen in photo) and if you know whether the Robur press dies would fit, or, if not, what alternative dies might as I am having trouble sourcing original ones.   I know that the subject of crystal presses has been a well covered topic here, so I apologies for bringing it up again but I hadn’t found any past threads on this points. Any help on this would extremely helpful. Thanks! Joshua
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
