My K&D staking set has no finish from removing the rust and grunge. I was wondering what The practicality of bluing was? Has anyone tried something like this. Any information would be greatly appreciated. I would prefer to do it myself.
Thanks
Assuming that the parts you want to blue are steel there are two approaches to bluing.
The first is heat which I would not recommend as you're going to need to get a lot of heat into it and the chances of warping or otherwise distorting it are high, let alone the risk of adversely affecting the hardness of the frame.
The second approach is to chemically blue it using a treatment that is applied to the surface. As a teenager I used to restore vintage air rifles and tried a number of the proprietary preparations with varying degrees of success. The most critical factor seemed to be degreasing and absolute cleanliness in order to avoid a blotchy and uneven finish, but if I got that right then the results were fairly good. You will need to ensure that the surface finish is even before you start though, either a really good mirror polish over the whole surface or an even grained or brushed finish as any variation will be very obvious in the finished item.
It has been a (very!!!) long time since I played those games though so I'm somewhat out of touch with brands that are available, your best bet might well be to browse a couple of gunsmithing forums and web sites to see what the current state of the technology is.
Also, it might be worth waiting to see if Geo has any input as I know that he has also had some gunsmithing experience.
Another alternative might be to use what I think is called black lead. I know nothing about it or how it works other than that it used to be used to keep cast iron stoves and fire places looking good.
As usual I agree with you Marc.  Preparation is everything, the polish, degreasing of the item and the careful even application of the blueing medium is all important.
I used to use a cold blue for re-touching  the finish on target firearms I worked on, it was quick and easy and gave a very acceptable result regarding appearance. This does not give a finish that is anywhere as durable as the original finish and will have to be re-applied now and again.
Here is the brand that I use.
If you decide to use this, remember to rinse all the blueing fluid of then blow dry.  Once dry, oil the surface to prevent corrosion.
Tim
A process called rust bluing is the way to go. It's very easy and looks beautiful,  but it is a process that needs to be learned. Again google and u tube are good resources.
I do a lot of it, I have been restoring vintage firearms for a while now. I have a cottage on OAK Island and would be happy to walk you through it next time I'm down.
Tom
Chemical bluing is the way to go.
A couple of years back I was working on making John Wilding Foliot clock, attached is a photo showing one weight before chemical bluing and one after.
The bluing is still perfect on the weights.
I just visited a local gun shop and asked them for gun bluing chemical.
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
