You can post now and register later.
If you have an account, sign in now to post with your account.
Looks to be in good condition, and fairly modern. I've never seen a bent regulator arm like that. Also the click is in an odd position. Should make identifying easier.
Might be able to identify it once the diameter is given and a photo of the keyless works but no guarantee.
Ancre-----Lever escapement
Levees visibles---visible (jeweled)pallets
Double Plateau-----double roller
Spirale Breguet--Overcoil hairspring
Balancier compense----Compensated balance wheel
15 rubis---15jewels
