2824 keyless problems
AP1875
So this morning I serviced a Chinese 2824 I have. I completed it with no issues (or so I thought) and started to give it a good wind to check the power reserve etc when all of a sudden the keyless was just spinning freely when trying to wind.
I put it into the quick date change position and all ok.
I then placed it into the time setting position and it was ok.
So I took the cover off the keyless to check it out. I've found that when I put it into the winding position the sliding pinion is not moving close enough to engage the winding pinion.
I rebuilt it and now it will wind and quick date change but I can't set the time.
The yoke determines the movement of sliding pinion (which is seated correctly in the pinion).
What controls the yokes movement, it's as if it needs to push further?
Any ideas appreciated
So as I removed the spring this is what I see, the setting lever has jumped on top of the yoke. Now I don't know if this had happened as I've taken it apart but I think that would explain the reason why I can't set the time as the lever wouldn't be able to push the yoke/sliding pinion all the way back (please correct me if I'm wrong).
Now I just need to work out why this is happening, it should all be held in place.
Cover plate back on.
As it was in the wind position when it went back together, winding was ok. Moved across to date and time positions all ok. Tried to place back into wind position and the same problem - sliding pinion won't engage the winding pinion.
Ok, so when I adjust this screw for the spring that seems to affect whether it will engage wind or time set.
Tighten it right up - no wind function
Loosen it off - no time set position being achieved
It's half way between now and all functions work [emoji848]
Would this suggest the spring is damaged bent or something else to you guys?
(I'm really sorry this isn't all in one post)
(This is the screw I adjust)
It sounds like you may have over tightened that screw. remember we are working with very small tolerances here have you checked the setting lever spring to see if the plate around the hole has bent or deformed in any way causing it to pinch up to the yoke when tightened.
Look closely at the ends of the bridge screws (which screw in from the dial side) there should be a short one which goes where the yoke/ spring fits. if they're in the wrong place , the longer screw will stick up and interfere with the movement if the yoke.
HTH
Anil
HTH
Anil
This is a very good point, I didn't think of that. From looking at the picture that would be the screw just under the crown wheel. I think I have the correct screw but maybe when I tighten the screw from the spring right down it catches...
No need to hunt for a correct screw, Chances are its been swapped around. Remove them one by one and see if one is shorter than than the others, not only the barrel bridge but also the train bridge and balance cock screws as they're the same type.
rgds
Anil
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
