Tiny jewel
TimFitz
I'm having trouble installing a roller jewel in a size18 pocket watch, even with a movement this big the jewel in just so tiny I have trouble with it. I have lost three jewels trying to replace it. Even with my magnifier it's so tiny I can't maneuver it around without loosing it. Is there anything I'm missing?
The roller table is off and in clamped in the tool I'm using good tweezers and read everything I can find about the procedure to no avail, ping there gone!!
I can't even imagine working on wristwatches!!!!
So far I've found handling jewels with tweezers to be a challenge. In fact, I often use a jewel picker-upper -
https://www.cousinsuk.com/product/jewel-picker-upper-with-silicone-tips
because pinging jewels is no fun. The other thing that is helping me is to use a softer, less springy brass tweezer. Well dressed, of course. That and I think I'm just gaining a better touch using the tweezers, due to practice, ping, then more practice, then ping, etc.
6 hours ago, szbalogh said:
To grind my Ellipsenstein shorter I mounted it in a pin wise. First, i have bent a 0.1mm soft copper sheet in half, put the jewel in it, then placed them in the wise and tightened. Then You could just place the table over the jewel or whatsoever.
7 hours ago, oldhippy said:
Rodico might help. Are you sure you have the correct shape and size for the hole, some are oval others round.
Yes ,It's a D shaped hole, I'll try Rodico
Do you use the small, me,or large jewel picker upper? Just purchased a brass tweezer.
Would bronze tweezer be ok ?
I have all three picker uppers. Rodico or rub-off or Blu-Tack on a piece of pegwood or a toothpick will do the same job, more or less.  I have both brass and bronze tweezers, at the moment I prefer the brass, the bronze are a bit harder/stiffer and I like a light action. Easier for me to feel how hard I'm holding something.
Preferences may and will vary with the user, phase of the moon, amount of adult beverages consumed the previous evening, amount of coffee consumed this morning, humidity, banging from construction work,   etc.
It's the coffee that make my hands unsteady. But I cant function without it , after spending time In the US Navy.
But that is a whole other story.
Yes, coffee is a strong enemy of me as well. If i dont drink then my hands are shaking and i fell asleep. So i drink more and more :)
Here's the method I used. I don't know if others have tried it. I dip my tweezers in acetone (nail polish remover). That leaves a microscopic film of acetone on the tweezers. That's enough to cause the tiny jewel to adhere to the outside of the tweezer. (I don't put the jewel BETWEEN the two blades of the tweezer.) while the stone is adhering to the outside of the tweezers, set the stone into its position. The acetone, meanwhile, is quickly evaporating, so by the time the jewel is in place, its adherence to the tweezer has diminished very much, and the jewel detaches easily from the tweezer.
Good Idea, will give that a try, Thanks
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the whole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
