I am not as lucky as AP1857 who has found its lost clickspring. I was thinking making a new one from ball pen spring.
Searched the whole house for ball pens yesterday and collected a dozen of springs in different shapes strength and finish. All of them were made from to thick wire so i just tried to shape for practice. Did someone shaped so small springs like this?
At room temperature i could not bend it to a sharp turn needed. Then mounted in a pin wise and heated to red with a torch but as grabbed with a tweezer it cooled down right away. What do You think, how could i bend the two hooks at the ends?
It is this type of spring,
And finally i could find one ball pen with four springs with a thinner wire,
Fir right-angled bends I use a pair of non-serrated needle-nose pliers like Lindstrom. For curved bends I ususally bend around a screwdriver shaft. Probably easier to make the bends with a longer piece of wire and then cut down to size.
Fine steel guitar strings are good for this job, at least you are staring with a straight piece of wire and not having to fight an go pre-existing curve.
Thank You guys! I have a tweezer like that somewhere, but will have to grind its tip.
Ah yes guitar string, and somewhere i have read that piano wire might be good as well. To the latter i was running totally accidenttaly. On the wedding the bride offered her old piano to our kids. We only have to organize the transport and retuning and started looking for piano wire on google. And this was before i started looking for spring material :)
you can  buy "rounding pliers".  they look like needle nose except the jaws are round tapered pins.  check our  "jewelery tools"  vinn
This spring from a thinner wire is really easy to bend. I could make the click spring from it. It seems its a bit stronger than the lost one. The ball pen spring is 0.22mm thick and the other common springs are made from 0.3mm spring. So a guitar or piano wire with 0.2mm would be perfect.
This is the watch i had to repivot both end of the balance staff. Yes i know, the hairspring is not true.
Here is some information on spring steel. It is also sometimes known as "music wire" or "piano wire" but would be too tough for a guitar string.
This article needs additional citations for verification. Please help improve this article by adding citations to reliable sources. Unsourced material may be challenged and removed. (March 2009) (Learn how and when to remove this template message)
Steels and other iron–carbon alloy phases
Microstructures
Classes
Other iron-based materials
Spring steel is a name given to a wide range of steels[1] used widely in the manufacture of springs, prominently in automotive and industrial suspension applications. These steels are generally low-alloy, medium-carbon steel orhigh-carbon steel with a very high yield strength. This allows objects made ofspring steel to return to their original shape despite significant deflection or twisting.
Grades[edit]
Many grades of steel can be hardened and tempered to suit application as a spring, however some steels exhibit more desirable characteristics for spring applications.
Common spring steel grades
SAE grade
(ASTM grade)
Composition Yield strength Hardness (HRC) Comments
Typical Maximum
1074/1075[2] 0.70–0.80% C, 0.50–0.80% Mn, max. 0.030% P, max. 0.035% S[3] 62–78 ksi (430–530 MPa)[4] 44–50[5] 50 Scaleless blue steel
1080 (A228) 0.7–1.0% C, 0.2–0.6% Mn, 0.1–0.3% Si[6]       Piano wire, music wire
1095 (A684)[2] 0.90–1.03% C, 0.30–0.50% Mn, max. 0.030% P, max. 0.035% S[7] 60–75 ksi (413–517 MPa), annealed 48–51[5] 59 Blue spring steel
5160 (A689)[8] 0.55–0.65% C, 0.75–1.00% Mn, 0.70–0.90% Cr[9] 97 ksi (669 MPa)   63 Chrome-silicon spring steel; fatigue-resistant
50CrV4 (EN 10277) 0.47–0.55% C, max. 1.10% Mn, 0.90–1.20% Cr, 0.10–0.20% V, max. 0.40%Si 1200 MPa     Old British735 steel
9255 0.50–0.60% C, 0.70–0.95% Mn, 1.80–2.20% Si[9]
301 spring-tempered
stainless steel (A666)[10]
0.08–0.15% C, max. 2.00% Mn, 16.00–18.00% Cr, 6.00–8.00% Ni[9] 147 ksi (1014 MPa)   4
david
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
