Wrench with a small diameter
jermy
Hi,
I'm looking for a watch  back case opener wrench  "who have 3 jaws" which the min diameter is 10mm,
So far I have found (a wrench with 3 jaws) only 17mm
Also found tools with 2 jaws even less, but I'm after a wrench with 3 jaws...
Can someone direct me to such a wrench (if it exist at all)
TIA
I had the same problem with a small ladys Cortebert.
Put the watch in a vice (I suppose it is too small to securely hold by hand) and use a small pair of tongs (pliers,clippers I don't know the exact word for it) that would fit in the back case cuttings. I'll try to take a photo tonight.
Hi jermy, sorry, I don't think anyone has really been looking for something that small -- only you -- so chances are no one has that information (smaller wrench in the market). All I can say is that some people open the back of even divers with an old caliper...but again that's only 2 prongs!
Any specific reason it has to be 3?
Cheers,
Bob
It seams that way, I wasn't able find smaller than 17mm (with 3 jaws)
That's why I came here
Quote
I need it stable, it won't be with 2 jaws
    • Hi and welcome. First of all, check the power reserve. If the watch is runing, this means the spring is attached to the barrel arbor. If there is no end of winding, this probably means that the spring is not attached to the barreland it's outer end is slipping. In such case, the watch will run, but the power reserve will be small - about several hours
    • Hi welcome to the forum. One can only reiterate the diagnosis already made by clockboy mainspring problem. But before tearing it to pieces take a little time to read the attached file to acquaint yourself with all the various parts. TZIllustratedGlossary.pdf
    • We think about these preps as "one-dips" partly because they are terrific solvents but also because the parts they are used on are often cleaner in general than many other parts. But old oils petrify, and even something like B-Dip can't clean up over-soiled parts without some extra effort, as mentioned above. There is an intermediate step during cleaning where the solvent can partially dissolve tarry residues so they have a more liquid varnish-like consistency, and that could well be what you are seeing on the coils after two washes. I wouldn't worry that your B-Dip was contaminated before you used it on this hairspring, but it I wouldn't re-use that aliquot AFTER this cleaning!
    • Welcome to the forum, enjoy.. Normally if a hand wound watch does not fully wind ie just keeps winding there is an error with mainspring, either slipping around its winding arbour or the mainspring is broken.
    • Most all my 404 candidates are coming from swap meets and "antiques fairs". One more $4US plus battery and elbow grease. Unnamed digital on a decent ss bracelet. Gains 10 seconds a day so not that accurate...
