Omega cal 503 part needed
Just came back from total restore and wanted to make a small adjustment but when opened I found the screw cut off with no slot . So I need a new part. It's been a year restoring it and I don't really want to send it back to the guy for like the fifth time. He's two months before he even looks at things. Here an image of it now and before ! See the difference! Help
Richard
410-336-6490
That's a shame... For what it's worth I never use the swan neck adjuster - I just move the regulator itself. It's a friction fit, which allows the watch to be adjusted while leaving the pointer centred so it looks nice for the customer :-)
So although your watch man has bodged your watch, you can still adjust it, albeit with more care...
I looked up the part number you need and the image shows the screw already in place? So it's possible by ordering the spring that maybe the screw comes with but the screw is also available as a separate part. Then fortunately this part goes back to the base caliber 500 and looks like the interchange with basically most of the 500 series.
Then if your watch is fast by 6 seconds I wouldn't worry about it Omega has a specification for this watch anywhere from -1 to +21 seconds per day average in three positions over 24 hours.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Omega_503
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
