Hairspring Manipulation
I have a hairspring from an Enicar 410 and it appears to be conical. I have it off the balance and mounted on a stake. What's the best way to get it nice and flat?
The watch doesn't run at all well the way it is at the moment.
I don't know how much conical it is, but the screw holding the end stud is there to correct the HS on the vertical plane. Worth a try before starting messing with the spring itself.
If the hairspring itself is distorted to a cone, repair is nearly impossible, all coils are deformed then. You can try to deform the other way (pull the collet) to get a flat plane again - success is uncertain.
What can be done with a deformed hairspring (only limited locations of bending):
Regards,
Frank
I think you may have the best approach. I think I was chasing something that wasn't there, and in doing so, created problems for myself. I think it may not have been the spring at all, but rather the rate adjustment lever. I may have distorted it slightly when reinstalling it on the balance cock, which pushed the pin and boot out of parallel.
I wouldn't say it's running great, but it is running.
With that in mind, what is considered the best and safest way of reinstalling the adjustment lever of the type shown in Frank's pictures above.
Edited by ftwizard
Did it come off or did you take it off. If you did why you don't have to. They can be tricky as they can break easily. I remove balance and hairspring lay the balance cock flat on a piece of rodico flattened out it stops it from moving about as much then gently push the lever on from one side I use 2 pieces of pegwood one to hold one side the other to push the other side into place just be very gentle ( I mean very very very gentle.) and it should pop back on it should have a gap in as you can see in Franks pic that opens up and closes when it clicks into place its like a spring. Also if there is a visible gap in it lay it on top and hold it in place with a little downward pressure and put a small driver in the gap and twist to slightly open the gap further and it should slip over I've done both you just have to be very gentle. HMMMMM did I say gentle enough in this reply :D
Yes, I did it pretty much the same. The only issue is the pin and boot. If you are not extremely careful they can get damaged so easily. I just wondered if anyone has a foolproof method that avoids any chance of damage to the regulator pin and boot.
I removed it during service, to clean the balance jewel.
If you are carful you shouldn't damage them just make sure the boot is closed first. Did your balance have a incabloc spring as shown in Franks Pic again you only need to unclip the spring and remove the jewels to clean them.
Nope, screw on type. Anyway, I've learnt another lesson, so that's a good outcome in my book.
Only problem now, is it keeps stopping and starts if I move the winding crown, either in winding mode or setting mode. Strange.
    • Most all my 404 candidates are coming from swap meets and "antiques fairs". One more $4US plus battery and elbow grease. Unnamed digital on a decent ss bracelet. Gains 10 seconds a day so not that accurate...
    • I voted.for the 6.99 assuming £, which works out to $8.74US at the current exchange rate.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
