You out there that do some tinkering with other peoples watches. Do you often get them back? Have had some bad luck lately? There always seams to be something wrong with the watches? Like watch running good but have a bad duration time. Or running fast  even though it works alright when leaving me. It's putting me down? Or quartz watch that losing time.
Do you have such periods to?  How do you do. I think i am getting more and more meticulous in my work? So what shall i do next?  Have learned a lot.
Edited by rogart63
Sometimes you may miss something the first time round, most recent one I had was a hairspring that was slightly bent. Coils were touching at one point, I demagnetised and cleaned it and it was running fine but the owner came back the next weekend with it running fast. Had to tweak the spring a bit.
The most important part is to identify issues from the start, looking at each and every component as you go about dismantling. Just because you found one problem doesn't mean there are others.
Anil
One thing I ask when repairing/servicing a watch is I ask the customer how they wear the watch. I ask this so when regulating the watch I can get the positional error in favour of how the watch is going to be worn. i.e my wife wears her watch with the crown facing away from her wrist, some take their watch off at night so for approx 7 hours it runs dial up.
Another question I ask is how well the watch was keeping time before it stopped etc. If I am told it runs a bit fast I explain that I should be able to improve this BUT mechanical watches will lose or gain over time it is just impossible to achieve perfect timing.
Absolute logic to what your saying. When I'm regulating a pocket watch I tend to concern myself to how it's performing Face Up and Crown Up or a wrist watch Face Up and Crown Down.
Sent from my SM-G920F using Tapatalk
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
