Old Crown
Hello Folk,
I found this crown amongst a batch I bought and noticed the writing on it.  A chap has one for sale on Ebay for a ridiculous price and he claims it to be an old Rolex crown.  I simply do not know and wondered if anyone knew.  it would be nice to get a return on it but I am a tad skeptical. It bears the words Brevete Depot International.  Any advice would be gratefully received.
post-197-0-02576400-1400744245.jpgpost-197-0-11612300-1400744246.jpgpost-197-0-03819800-1400744247.jpg
Well, "Breveté" is simply the French for "Patented". When people call a Swiss watch a "Breveté" model - that's all it means!
I can't, off the cuff, think why Rolex should put anything other than "Rolex" on a crown. But, if you see another old Rolex with "Breveté Depot International" on the crown, then I'll be proved wrong!
Thanks Chaps,  I thought it sounded odd.  Just in case you are interested here is the link - http://www.ebay.co.uk/itm/Vintage-Crown-Marked-Brevete-Depot-International-Early-Rolex-5mm-has-CaseFlange-/191007306723?pt=Wristwatches&hash=item2c78ec33e3
I should put mine up for a fiver next to his but with no claims about Rolex and it might go, then I would be £2.00 up on what I paid for the crowns (:-))
Cheers,
Vic
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
