Caseback gasket for Seiko 4205-0150
I just purchased a used Seiko 4205-0150 for my wife to take on our upcoming trip to the Caribbean. The seller claims that it has been recently serviced, but I still have some doubts. Esslinger carries several of these gaskets, but they require the part number. Rather than waiting until the watch arrives to find the gaskets are no good, I would rather order the part now and have it here just in case.
Does anyone know where I can find correct part number for this gasket?
Thanks
1 minute ago, vinn3 said:
"seller claims"  the last " serviced"  crono i bought had NO gasket.   you need the service recept or being lucky.  vinn
Vinn3,
I know. I am not convinced the "service" was more than just a cleaning of the case and changing a strap. I will be opening up the watch and taking a closer look as soon as I receive it. I purchased a "recently serviced" Seiko SKX007 and the caseback and stem gaskets were completely dried up.
1 hour ago, Blacklab said:
According to Boley & Jules Borel it should be FF277BAA1
Thank you. Seems like this part will be more difficult to find than I have originally envisioned. Jules Borel is out of stock. May need to buy from overseas.
It's a common flat gasket o.d. 29.70 which you can buy by size from any materials house like e.g. Cousins UK.
Thank you. I will look for a gasket with those specifications then. I appreciate your help.
I was able to order the FF277BAA1 gasket from Cousins. Seems like they have reworked their website from the last time I visited. I hope these gaskets arrive before we leave for our trip.
Thanks everyone.
11 hours ago, ricardopalamino said:
Hi jdm , how or where did you get the o.d. dimension for the gasket ?
From the watch itself. I also share a small database of Seiko gaskets sizes https://docs.google.com/spreadsheets/d/12F3W8LcLQXWCkd8G0U7g4KaKfUTox9FayfNlKEUfdFY/pubhtml
When buying generic the advantage is not only easiness and savings, but also getting a pack of 2 or 3 which can be used on other watches.
Thanks jdm , and ro63rto for the info . Is the bezel gasket for Seiko divers in this mix by any chance . They're kinda costly one at a time .
Where do you source these generic gaskets?
Good luck with your gasket rodralph.
Edited by ricardopalamino
If it's not there measure it or tell for which watch it is. As mentioned Cousins UK has a very large selection of sizes and shipping is cheap to worldwide.
2 hours ago, ricardopalamino said:
jdm , do you order the O.D. in the generic gaskets ?
I measure everything and order the most suitable, for simplicity I referred only the O.D. in my first post here.
Update:
The watch arrived last week and needless to say, she is very happy with it. The smaller size suits her wrist size very well. The watch came with a Nato strap which she did not like. Replaced it with a Zuluband in blue. She loves her new watch.
As far as the gasket, the watch did have one installed. I am planning on getting the gaskets lubricated with silicone oil this weekend to prepare it for our vacation next week.
After replacing and lubricating the gaskets, it survived three days in the Caribbean San Andres Island. She is very happy with it and now wants a modified one with an orange or purple dial. What have I done???
I forgot to update this before...
The movement was in pretty good shape and fairly clean. The gasket that came with the watch was the wrong one. Thankfully I had order some correct ones from Cousins and they arrived on time for our trip. I also noticed that the crown did not screw all the way down. I greased and replaced the gasket and shortened the stem about 2mm. After that was done, the crown screwed all the way down and now sits flush with the case,
I still have to adjust the movement as it runs about 5 minutes fast every 24 hours. I will work on that once we get back home,. For now, it has served its purpose.
Opened the door for the next adventure .
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
