watch ticking but hands moving slowly
I am assuming that the seconds hand is ticking normally, but the hour and minute hands are either not moving at all or are losing time erratically.
If this is the case then one of the most common causes is a loose canon pinion. Another symptom of this is a lack of any resistance at the crown when you set the time.
Note: your movement appears to be an AS calibre. I can't tell which one but it looks to be something like a 1950/51 family. AS movements don't always have the canon pinion where you think it should be and the 1950/51 use an off set arrangement with the canon pinion sitting between the setting wheel and the minute wheel.
Marc I think your right about the cal and cannon pinion. Its such along time ago with me I'd forgotten, my brain cells are now working and am I right in thinking the cannon pinion is very short and is difficult to tighten.
thanks for the reply I think it's an AS ST 1902/03 I can't remember off the top of my head, when I pull the stem out to set the time it feels fine, they do move but really slowly.
Just to clarify your last statement - when you say "they do move but really slowly".... Are you also saying that they move relatively slow when you use the crown to set the time??
Regardless - it would seem that your issue lies somewhere in the motion work - cannon pinion, minute wheel, hour wheel,... If the tension on the cannon pinion is good, I'd check the alignment of mesh of all these components under the dial...
when setting the time all seems normal, but in reality 15 mins in normal time the minute hand moves only 2 mins if that makes sense.
Ok so this is a common problem with a AS1900-1906 movement  it has a friction pinion on he intermediate wheel which needs tightening see this thread ive had to replace a couple of them managed to tighten one they are available from cussons
thanks
OH on a side note the same friction pinion is used in the 1904,1906 ,1914,1916 ,2064,2066 and 2164,2166  so if you have any parts movements lying about doing nothing use it as a donor.
I don't have any can you still get part's for this.
Yep find caliber number and cussons have the parts or troll the bay for non working AS movements but there's no guarantee the friction pinion won't be shot on those either cussons would probably be your best bet.
thanks mate :thumbsu:
9 hours ago, rogart63 said:
Could have some old movement laying around here somewhere? Send me a PM and i should take a look tomorrow. Maybe even a NOS part?  Needs to take a nap first :)
Thanks rogart63 when I get back from my cruise in 2 weeks I will strip it down and have a look what is going on,it's a 1802/03
thanks
Had three old AS 1950 but in everyone of them they had taken the cannon pinion. So i guess the it's a common problem. Have more parts and take a look if i find something. Cruise a little for me also :)
thanks mate:D
    • “Traditional” was probably a poor choice of words. What I was trying to say was that I perceived Waggy's proposal as more modern than the now generally accepted one. Water and sugar? Do you have a source on that or is it just a guess? Is the inside of the crown stainless? Water and metal don't sound like a very good combination otherwise.
    • Hello and welcome to the bottomless rabbit hole! 😉
    • Do you use an ultrasonic cleaner or a watch cleaning machine? I've been considering trying out the L&R liquids you mention in my "ancient" Elma watch cleaning machine. However, I worry that these liquids are too toxic and smell too much without adequate ventilation. Where I live it is normally too cold to work with this outdoors, but a few months a year it could work. At some point, I tried Elma's Suprol Pro and almost passed out from the fumes. It comes with a "narcotic effect" warning. How bad are the L&R fluids in this respect?
    • I've removed the movement and left it on a windowsill. I'm in north east England, so not very sunny today 😥 however I'll give it a few days and then try a new battery. The document you sent claims the movement is the same as the C700 with regards to parts and assembly. I've managed to find an exploded view of a C700 and some troubleshooting instructions. So if a new battery doesn't work in a few days I'll strip the watch and test the electronic circuit unit. No doubt it will require cleaning and oiling anyway. Thanks again for your help @watchweasol
    • Hello and welcome to the forum,     Enjoy
