Hi all, working on my 5106- xxxx, with 33 jewels, no less, and two things have come to puzzle me that I'm predicting someone here can resolve.  One, I'm pretty sure the cap jewels under the tiny "C" spring are flat against the pivot and domed against the "C" spring.  The reason I know this is my watch runs after cleaning, but reluctantly, so I suspect a jewel is in upside down and that domed face has removed any end shake and/or added preload.  I did look carefully, and could see any, but those jewels are really tiny.   Second question, is there a technique and/ or tool someone can recommend to remove these little blighters?  I've used the tip of my tweezers so far and distorted one spring, and savaged another.  There has to be a better way.  The big tri-lobed spring for the balance is no problem, by the way.  Suggestions?
Put a 10x or 15x and check if the jewels are the right side up.
About the springs, search for seiko diafix. I think they are close. Basically you push from one side. Imho they are a nightmare!
Good luck!
The diafix springs are a pain i the b... .I leave them alone if they aren't very very dirty. Clean them with the plate or bridge and oil them from underside.
I bought some old movements with diafix springs for using as spare parts.
Look in the video section for the 7S26 strip down and repair. In the conclusion video, Mark show how he deals with the diafix jewels.
The c-shaped spring has a tab in the middle which is caught under a lip/groove.  Use a sharp tool and move the tab out of its groove. You don't need to lift because the spring s slightly  bowed when installed and will spring up. The two ’legs' will ride down in the groove, bending slightly to match the radius of the groove.
To install, fit the two legs in the groove, it should go in the grooves easily, then put the cap jewel in place. Next, slide the spring so the tab in the middle clears the lip of the groove, then use another tool to press down on the tab while pushing the spring under the groove .
Like anything else in watch repair, it gets easier with practise but I prefer working on these than the ones on the 7s36 models.
Oh, I would start by working with the movement inside a plastic bag!!
Anil
To add...these cap jewels are supposed to enhance the timekeeping qualities. Personally I feel that not cleaning them when servicing  is wrong.
Just my opinion tho’
Anil
Thanks, all.  Nice to know I'm not the only one who curse these, and keep a donor movement on hand.  Anilv - thanks for the insight into using the center tab by moving both legs into the groove.  I'd noticed that installing is hard, because the c spring has to be perfectly centered or a leg kicks out.  Never thought of getting the center out first, then reversing that for install.  I can hardly wait to get back to the bench and try your technique.
again, thanks for the collected wisdom.  And I always think cleaning the jewels is worthwhile, if you know what I mean.
  • Similar Content
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
