I have not been on for a while and just popped in to say hello to all, been a tad preoccupied with non horological stuff, DIY and Holidays.  Had a couple of weeks in Crete and shortly off to Los Angeles for a month.
After swearing not ot buy anything else until I got my finger out and resolved some of my outstanding projects, I was seduced by a battered Tissot seamaster and a Helbros Bumper for a grand total of $24.00 so they are waiting for me in LA now, it was the Bumper that piqued my interest and the Tissot was just with it in the job lot.  I may pick up a staking set while I am over there.
I am going to try and find some of those legendary "Flea Markets" in LA, I will be in the Alhambra area and the tinternet has already provided me with several options but if anyone has any local knowledge on good places to get old unloved watches to repair please advise.
Anyway I will look in occasionally from LA using my sons superfast internet and best wishes to all.
Cheers,
Vic
Have an excellent time Vic and happy hunting my man but don't forget the excess  baggage charges from all the watches you'll  pick up. :D
Have a great trip Vic, pity I'm on the other side from LA...and no vacations yet! I'm sure you'll have a great time and check out plenty of watches there!
Cheers,
Bob
Happy hunting. If you're in the states and looking for a staking set, lookout for an "Inverto" set. Supposed to be very useful. I don't have one (Mines Favorite) but happy hunting anyway
Tony
Sent from my SM-G900F using Tapatalk
Currently surveying the staking set offerings keenly and am watching and deciding.
Cheers,
Vic
Well I finally made the decision and I think I did ok for £127 plus £12 postage.  The seller was selling his grandfathers equipment off. The staking set with jewelling attachment is pristine with no blocked holes and just needs a couple of additions like a sprung Jewel centre punch
That's a lovely set you've done very well there and at a bargain price . Thas dun reet well theer lad ( as they say in Yorkshire )
Mick
Hello from L A again,
well I have been to a flea market and there was a load of watches but mainly 2nd hand modern Quartz. The only guy selling vintage watches was a tad pricey and the watches were beaten up and I could do better on the bay.
Speaking of which I have bought about 6 watches since being here some working some not but nothing very rare or high value all worked out at about $15 and I would have been put off in the uk by the postage cost but being here it was about $3.50 so at current Brexit rate that is about £15 a pop.  There is a promising looking Waltham and Tissot amongst them and I managed to get an Accutron 214 movement that I need the tuning fork from. Luckily I noticed a tiny screw stuck to it near the coil so I am hoping that proves it retains its magnetism and will work for me. (Top tip - never demagnetise an Accutron hummer - it ain't the same as clockwork), also if the screw is what I think it is that is handy as well !.
Cheers,
Vic
Well I am back home now and have unpacked the staking set and had a proper look at it. Surprise when I looked inside the staking / jewelling tool.
Turns out I have a K&D No. 600 and when I checked the punches a lot are marked as K&D as well, I have not looked at them all yet but there are 131 and 34 of the stubs.
Quite happy with the way it has turned out though
Thanks Mick,
just got to learn a bit more about how to use it and will go after the book that George suggested. Already found out the small ones are stumps not stubs.  Also managed to download a hi res copy of the K&D manual. Think I may have a nap now all this excitement tires you out !
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
