Tool for straightening pivots?
rogart63
35 minutes ago, Cad101 said:
hello Seitz do a pivot straightener I think I remember seeing one while surfing one day and nearly having a heart attack at the price.
That would be no surprise? Seitz shall have a look? Exactly but this was obsolete at cousinsuk.https://www.cousinsuk.com/product/balance-staff-pivot-straightening-tool
Edited by rogart63
  • Sad 1
12 minutes ago, szbalogh said:
Is it heresy to straighten in its own hole?
In my book, nothing is heresy as long as it works and doesn't screw things up more! If the plan is good....go for it! I've never done it so let us know how you fared!
Cheers,
Bob
I don't think you would get a perfectly straight pivot by using its own jewel to straighten it because of the hole tolerance. As I could see the pivot straightener uses progressively smaller jewel holes to straighten the pivot. Using the movement hole you would still have a slight bend which would bind with the jewel and cause friction which would affect your amplitude. But then again I may be wrong.
Cheers,
Bob
Did it with the Roskopf's escape wheel pinion. It is not jeweled just a hole in the brass plate. Now its barely visible and running great but You are right, its not perfect. And i think that there is maybe a chance that in a jeweled hole it can crack the jewel?
I was thinking this may happen too. There is always the pivot sizing tool I suppose, those that don't have jewels...would they work?
2 hours ago, ramrod said:
what pivot are you straightening? what movement?
Haven't got any pivot right now that needs to be straighten. I saw a great blogg by a Swedish watchmaker and he used a tool for straighten a balance. Looked so cool i had to find out more about the tool.
ah. got it. the reason i asked is that i won an auction on fleabay about a month ago and it is all parts - stems, some crowns and 95% pivots. tons of them. i couldn't use them in a lifetime. i'll give them away for anyone that needs them.
  • 3 years later...
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
