So this has been an issue that has cropped up numerous times. When I've reassembled a vintage watch, setting the time is very "jumpy", it doesn't want to turn smoothly. I've used D5 on the inside of the canon pinion, and the outside as well. I'm sure a seasoned watchmaker will know what this is right away.
Thanks!
Thanks!
And the movement is?
A very early Valjoux Colomn Wheel Chronograph, mid 1930's. But this isn't the first time I've had this issue. I always wondered if maybe the hour canon pinion (not sure of the technical term) is too loose.
what does the stem feel like when you turn it :  Does it feel gritty or difficult to turn? Did you notice if it's always hard to turn when the hands/the stem reach the same position?
If the stem feels really loose then it could be the canon pinion slipping. If tight it could be a dial washer missing or perhaps the hands touching.
Not difficult, more like it wants to turn in 5 minute increments. Normal-loose-Normal-loose
Stem is normal, and time keeping has been perfect and matches my timeographer readings. I'll take the dial off this evening and check for a dial washer. Wouldn't touching hands affect the time keeping? they're close, but I don't think that close.
When you have the dial off, make sure all the teeth mesh properly (clutch, intermediate wheel...).
If it feel good with the dial off, it's got to be something with the hands
