Screw case back not coming off.....
Excellent advice! Mainspring winders are generally a nightmare. In order to be absolutely sure that they work, they must be adapted for specific calibres. Sure, you can build up a collection of winders over time, but it's expensive and time-consuming and you still can't be sure that any of the ones you have in your collection will fit. When I was new, I considered buying Bergeon's large universal set because I thought it would cover all situations, but that's not the case. The risks of hand winding a mainspring are often exaggerated. With the right technique and training, the risks are not much greater than with a winder. Moreover, if the spring has a T-shaped bridle, you may not even get it into the barrel. Here is an excellent description by a professional how to hand wind: Yes, a well-established practice among professional repairers is to always replace the spring even when it is in good condition. Personally, I think it is an unnecessary cost because modern springs last a very long time. Some fatigue occurs over time but if you are unsure, you can always test the power reserve. It is also an unnecessary risk to replace a spring if it is still in good condition. If an original spring is not available, it is not certain that the alloy in a generic spring corresponds to the properties of the original spring. This seems to be particularly true for some Japanese movements, especially Seiko and Orient. For any Swiss movement, I'd say the risk is non-existent.
By rjenkinsgb · Posted
I had a similar problem with a chinese set - with that, I drilled the drum out to take the slightly larger arbor; it only needed about 0.2mm increase so no detriment when using the original arbor. (One was LH the other was RH, in that case). -
There is a tool to straighten this, but it will cost you 50x this wheel. -
The devil's creation. They peeled off very easily, yeah no not recommended. -
You have a very low chance of straightening this, it should be made of hardened steel, which is very brittle. Maybe you could ask for a refund from the place where you bought it? If you go ahead and try to straighten it and it breaks then nobody will refund you.
