Jeweled pivot gauge measurements needed
BWT
Does anyone have a seitz or other jeweled pivot gauge? I have an idea I'm working on and needed some measurements of these tools.
Also I've noticed some of them just appear to be straight holed disc type jewels with no oil cups, can anyone verify this?
Thickens is about 1,05mm with 20mm length 115mm. Front face - jewels are flush with surface, other side not as jewels are not thick as this aluminum bar. Size of jewels is about 1mm, I don't think it matters as most important is hole sizes, so it can be any outside size for jewels if it has right hole in it.
For my needs it seems to be ok. I usually use pivots 7, 11, 14, so no half sizes, and rule for jewels for me is one size biger to get proper fit. You know 5% side shake etc.
Wysłane z mojego GT-I9505 przy użyciu Tapatalka
  • 2 months later...
