6mm lathe
chadders1966
Hi
Quite a while ago now I bought myself a 6mm Lorch and Schmidt lathe. If I had the choice again I probably would get an 8mm one instead, but this was a real bargain and came very well equipped so I've no regrets. I've not used it that much because there are problems with some of the collets I've not got round to sorting, and I've decided it's about time I did :).
There are about 30 or so collets, probably from a number of different lathes but fortunately the threading is the same on all of them. The problem is some of the bodies are longer than others, or the threads are longer, so that they are not fully pulled into the headstock. I can do a quick fix by making some sleeves/rings to effectively extend the length of the drawbar, but the best thing I think is to make a new drawbar or two. I could also do with repairing the threads on some of the collets so I need a tap and die.
According to the lathe.co.uk site the lathes needs a tap of 0.199" by 0.7mm, and fortunately my measurements agree. I've only found one source selling taps and dies with these measurements, GG Tools in Germany (actually 5.06mm) and they are 42 Euro each. I was thinking I might try a less expensive 5mm x 0.7mm tap and die to see if it is good enough, but I can't find a source for M5 x 0.7, 0.8 or 0.75 seem more usual.
Two questions really - does anybody know of another source - preferably European - for taps and dies 0.199" (5.05 or 5.06mm) x 0.70mm. In addition or instead a source for 5M x 0.7mm taps and dies. Thanks.
Stephen
1 hour ago, oldhippy said:
Try here http://www.thetoolbox.org.uk/
or you cold try Axminster Power tools here http://www.axminster.co.uk/?gclid=Cj0KEQjwo_y4BRD0nMnfoqqnxtEBEiQAWdA12x1ruuf7MaWPjgn97m8Ls-H8F0sp7aogUPeVVIrndAIaAo3l8P8HAQ
Just to say I have no connections with these sites. They are places I know and have dealt with in the past.
Thanks - I've sent toolbox an email to ask if they have anything.
54 minutes ago, rogart63 said:
You can kiss me some other time :) M5,2 x 0,7 is the thread size.
http://www.ebay.com/itm/Tap-for-Drawbar-6mm-Lorch-Watchmaker-Lathe-/111707669183
Thanks again, but I think I'll give the kissing a miss :D. It's good of you to look, but I did see that listing when I first looked some time ago. I contacted the seller who confirmed it was 5.2mm. I then pointed out that this wasn't correct for a 6mm Lorch, but they have obviously just ignored me.
I search on google? Tap watchmakers lathe collet 6 mm and that came up.
I was so sure i was right there?  But will keep looking.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
