I came across this on eBay (quite possible posting this may put it out of my price range....LOL) and it got me to thinking. At what point is a watch no longer serviceable or able to be restored. Part of me says this looks like a fun long term project and the other part says there aint no way.
http://www.ebay.com/itm/Vintage-Mens-JP-Pinguoin-17-Jewel-Formula-Analog-Watch-For-Parts-Or-Repair-/272217539969?hash=item3f616e0581:g:9z8AAOSwD2pXFn~r
Its always posible to restore if parts are available or if you have the skills & equipment to make the parts.
Rust is the killer.
  On 4/26/2016 at 8:56 AM, ro63rto said:
At what point does it change from a "restoration" and becomes "Triggers broom"?
For those wondering......
Trigger's Broom:
Expand
LOL - you beat me to it, first thing I thought of when I saw the title of the thread was Trigger.
Restoration of a watch like that depends upon the availability of parts or donor movement/s and the cost of those solutions, I have quite a few that are restorable, but the cost of the parts exceeds the end value of the watch.
Not so much a consideration if you want it for your collection, I'm not much into collecting I just like restoring them and cost becomes a factor as I try to sell some on to finance more victims, I would like to get hold of a chrono to restore but I get peeved if I can't find the parts to do so. So I have to consider all those factors before I buy a project.
So do your research, find out what movement the watch has then search the availability of donor movements or parts if the fault is known and work from there.
Max
If parts are rusted, because they are so small, is it safe to use naval jelly or vinegar to remove the rust and then polish the piece?
It's not a question of removing the rust its what the rust has eaten ,pivots cogs wheels etc and then you run into the cost of replacing those parts it starts overpricing the watch beyond its worth or if your like me begrudge paying £ 15 plus p&p  for a setting lever spring which is 3 times what I paid for the watch in the first place (but then I am a tight Yorkshire man) but if money is no object and you can find the parts needed and its a watch you've always wanted and you dont mind putting the hours in cleaning parts why not.:D
    • Hi 122146 - welcome to WRT 😊
    • You could try a soft-solder repair on that
    • Hi Logan, welcome to the forum 👍
    • So I recently picked up a slim 6105 which had a badly damaged dial (posted in another thread). I couldn't really live with that given I had another dial handy, also in not great condition but with added bonus of having a better lume job and actually being fully attached to the dial plate!  So what to do with that damaged dial - I tend to think they should be in watches. Well...  A 6105 mid case and crystal assembly punt arrived from Italy yesterday, which I've frankened back into a working piece with the dial... Damaged dial now sits behind damaged crystal in an original case, currently powered by 6106 (with a 6106 caseback on to reflect this... I've cleaned up the original crystal up to a point, but kept it fairly beaten to distract me from the dial, my markers and it's not very satisfying lume job - it's not awful but it's glossy which I don't like. Also has a 6139 bezel on it for now because that's all I could find - I couldn't live with it naked and don't mind it tbh, though will keep an eye out as ever.  So yes, here you go - another 6105 (almost!) back to life. I'll also keep my eye out for the correct movement and perhaps a better dial in time. Caseback might prove tricky/expensive. I know Frankens aren't to everyone's taste but I do enjoy getting these back into working form. Better a working/worn watch than a sat in parts draws imo. And the good news here is that, thanks to the repro service crown, this is the only one I have I could actually feel safe to swim in!
