My Cheap Hmt
dbals
Bought this on the bay for $8 USD with shipping. When I got it, it would run awhile and stop. Opened the back and literally removed two hairs and a small pebble. Been running about 15 sec a day slow. Gonna be the next candidate for cleaning and oil. post-174-13990378162045.jpg
Sent on the go with barley, water, yeast and hops
Actually, it ended up being two for $8 because the descript was that this watch was running well.  When I wrote to tell the guy that it stops a couple hours after winding he apologized and begged me not to give him negative feedback and shipped another one to me the same day!
Now I just need to find some technical doc on the movement-  I think I read this movement is based off of a citizen movement.
The last few weeks I have been reading and searching about HMT as I am interisted in a Janata myself. Can you please telll us is it worth getting as some people say it will go on for years, movement was by Citizen. I want to get one as an everyday working watch.
No way neither of the two I have would hold up for me for daily use.  I tend to be rough on watches- manage a research lab, which means I might have to be a plumber, electrician, machinist, histologist and/or general repairman everyday.  In fact, I have to look at the other HMT I have- suddenly I was gaining minutes each day and wondering if its magnetized as I was in a machine shop for several hours the day before.  Don't get me wrong I would probably wear them everyday if I wasn't so damn hard on watches.  I used the Citizen 201 movement document from Cousin's  website to take mine apart and they were identical.  Also,  both of my HMT Janata's (bought on ebay used) had their faces glued on with what looked like contact cement and let me tell you- what a mess.  Would I buy them again- yep!  I do like them-  Just keep in mind if your buying from ebay- take a good close look at the pictures.
My daily beater is a seiko 7s26 and have been really shocked I haven't destroyed it- whether I'm fixing  a lawn tractor, car or daily work.  It runs about 5-7+ sec fast each day and looks good.
Hope that helps-
Dan
Thanx Dan. I think I will try one. Cheap enough though. Same here, I do not wear a watch because I will destroy them in the first few hours when taking out some hidden car part designed for Germans with ridiculus small hands.
Yep, para shock is the Citizen shock protection they patented. Strong movement I believe. Nice catch Dan! I plan to work on the 8200 myself in the near future. I saw a page where the guy rebuild some divers that I just have to have one myself!
No, not HMT but Citizen brand watches, vintage. I was referring to the 8200 movement because the HMT also use a citizen movement or similar according to the post. I tried to add a link here but for some reason it is not working. Just do a google search "citizen 8200 restoration" you'll be able to find the page.
Just came across this thread today. I don't own an HMT, but I undoubtedly will at some point. I read somewhere the HMT 0231 movement is based on the Citizen 0201, which was also used by Caravelle/Bulova, and is the movement I'm using to practice on. If anyone still needs it, here's a link to a technical sheet:
http://watchmaking.us/files/3564_Citizen%200200,%200201,%200271,%200272.pdf
Hello Dan,
Nice looking watch and two for one can't be bad.
Good to hear from you, Just thought I would advise that here in geordieland a local Pub Chain Called Wetherspoons is running a "Craftwork" week and Devils Backbone IPA (5.2%) from Lexington Virginia, Lagunitas IPA (6.2%) from Pataluma California, Rogue Amber Ale (5.3%) from Oregon and Brooklyn Lager (5.2%) are on offer along with various Sixpoint cans - Sweet Action (5.2%), The Crisp (5.4%) and Bengali Tiger (6.5%) all from Brooklyn NY apparently.  I really enjoy steeping myself in other cultures hic burp :beerhat: .
Cheers,
Vic
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
