Locked escape wheel.
This just in...
I found that when I tweaked the escape wheel with a pin, it freed itself from the pallet, so although the upper jewel in the wheel bridge looked okay, on closer inspection it seemed to move, and when I pushed gently on it, it virtually crumbled and fell out.
I think the jewel is 1.1mm dia and have found one in another watch in my spares box, so since I have nothing to lose really I am going to try to replace the jewel. I don't have the right tools so I will work out a safe way to perform the job. Wish me luck!
The back-up plan will be to find another wheel train bridge. Yours in trepidation,
Frank.
Latest on the Vostok 2414: have found a jewel in my spares box, managed to remove it from bridge and have fitted it into the wheel train bridge of the Vostok and it looks pretty good. Going to have a well-earned beer and see if it will run when I refit the bridge tomorrow! I'll have to check for end shake. I really think my Vostok will live again.
Frank.
I see old hippy,s point one of the pallet stones does not look to be seated correctly. If so it will never escape.
If it does not work with either the new or old escape wheel then this is the fault. To adjust the stone position you will need a pallet folk tool, heat & shellac. A pic below is the tool I use.
The story so far:
Since I don't have the facilities for resetting the pallet stone, I risked sanding a few 'thou' off the stone using 1500 grade paper (the Tamiya stuff I use for models). I managed to do this without disturbing the pallet stone, and hooray, the escape wheel advances as it should with a few winds on the mainspring. With the balance fitted, it really wants to go, but I think the beat corrector is not set correctly. So now I will do a little research on this. I am convinced this watch will go, it just takes perseverance. (Quite easy with the rain beating down outside!)
This is probably a first Frank, :startle: I wait with interest to hear how good the end result is.
Best of luck Frank you have identified the fault but I will be most surprised if the sanding down method will work as the tolerances are fine to say the least. If it was me I would find another pallet unit & fit.
11 hours ago, fjseal said:
The story so far:
I can't believe this. Why not just order another pair of pallets, you are making a lot of work for yourself  fjseal.
    • Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
    • As Hector said they have too much  tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us.
    • Thank you and i appreciate that, it looks very different    Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
    • Donor movement showed up, so I stole the bridge screw from it. Which made me sad, because it's in such nice shape! It seems a shame. Maybe I'll find a use for it one of these days. Unfortunately, the stem is for a different style of case and is much too short. Fortunately, I ordered a brand new stem from McCaw Company. Unfortunately, the crown on the donor movement is thoroughly stripped out (it unscrewed in a shower of brass) so i just put the old stem back in for now until I source a new crown. As you can see, it's just a little too long for this case. Overall I'm super pleased. I didn't think I'd like the bracelet, and even that is growing on me.   Anyone have a favorite crown assortment?
    • A couple of pictures of the front… Sorry, I’m months away from this one, but…there is an edge to the bezel but I see no obvious signs of previous bezel removal and it is quite thick so it would be difficult to grab an edge on the crystal with a crystal lift. It does look like in/out thru the back…good luck…
