Elgin Pocket Watch Lift Angle
You will have to rotate the hairspring collar around the staff lightly. If you have not done any work like this before, I suggest you leave it as is.
If you feel you must, pick up an old movement to practice on first. Mark has some good videos on this kind of work.
is it called,
How To Align The Hairspring to set the watch in beat. Watch repair techniques
When he removes the hairspring, does he use regular hand removers? or are they smaller?  Is their a way to set the hairspring back on with out a staking set?
The beat error is not the problem.
do you have clean the watch ?
does the regulator affect the timing ?
if not, check the hairspring at the regulator pins.
To put in beat you don't need to remove the hairspring. Just turn it a little on the right side, but what is the right side ?
Let down the mainspring, then stop the balance and put it in rest so that the roller jewel is in the middle of the lever fork. Release the balance, if it is in beat it should stay at rest, if not it will turn on a side. Turn the hairspring collet on the same side. (this will turn the roller on the opposite side). There is a special tool for that but you can use a small screwdriver.
I suggest you read the Chicago Master Watchmaking course.
Not sure how you can place such a balance in beat without removing the hairsping.
You say turn the hairspring collet with a small screwdriver but how exactly?
Is that is explained in the Chicago course? Where?
The above, I don't know.
I do know you can rotate the hairspring around the staff using a screwdriver as long as it has a split collet.
    • If you're seeking advice for your "Harvard GSD" MArch II application essays, I'd recommend taking a thoughtful approach. Reflect deeply on your experiences, passions, and goals, and tailor your essays to showcase your unique perspective and potential contributions to the program. As for resources, I recently stumbled upon a gret platform for essays, and I must say, it's been quite helpful. Their selection of pre-written essays covers a wide range of topics, and their professional writers can also assist with custom essays tailored to your specific needs. Check out their offerings here: https://essaypro.com/essays-for-sale. Remember, authenticity is key in your application essays. Good luck!
    • For clarity and ease of testing, I redid that diagram, flipping the circuit to match the layout of the physical watch.
    • Hello, Thanks for the reply. The old jewel will get pushed out from the "outside" which is the dial side. The new jewel will get pressed in from the inside (shown below) which is the movement side, correct?     And the old jewel and spring will get pushed from the is the "outside" which is the dial side. Thank you very much for the information. I will take out the KIF spring and save it. Will update when the new jewel is in place!   Regards, Joe
    • It's a little circlip style retaining clip to keep the pinion from riding up out of position.
