If you're interested in my watchmaking projects, I have started a collection on my Google profile. I will start posting everything I do there along with progress pics, before and after shots, etc. I figured I would stop bothering everyone here posting project after project when the majority of you might not even be interested. I plan on servicing thousands over time and typically complete one every few days. Thanks for your time!
** kindly link to your personal blog in your signature not in forum posts **
Moderators: if this is not allowed here, I will remove this immediately! Thanks:)
I don't see a problem as long as you are not advertising for work. I'm sure the boss will keep you right!
Please bear in mind this It's a watch repair forum and folk like to see work being done by others. I personally would like to see all your projects presented on the forum. It's stiff like your projects that is the life blood of this place.
I'll post them up here too man, thanks!  Lol, no sales, I work in I.T. and only do this for a hobby/obsession;)
Can we please follow the rules regarding links to personal blogs being kept in your signature. No links to personal blogs within posts please. :)
It would be more helpful to the community if you post your repair stories in the forum itself, we love seeing how others get on with their jobs. Hope to see more from you in the future :)
Sorry about that, I will re-read the forum rules before posting here again
Edited by jeffc83
I for one will be looking out to see your work. Having had about 30 years it will be nice to see how watch repairs/makers go about their different ways.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
