Is it possible to get scratches out of a Seiko Hardlex Crystal. I tried with a drumel tool and various types of polish but was unsuccessful. Polishing the body of the watch works well, but the darn crystal scratches stay. You would think that making a scratch is less violent than 5000 rpm drumel with #2 polish.
From Canada
I think Hardlex clouds with the heat of the dremmel...too fast, too hot! By the time you "eliminate" the scratch the crystal will be unusable. A slower "way/machine" with gradually decreasing grids and, using a coolant, might work though.
It can be done as I did one for my 6139B for which new Seiko crystals are hard to come by a very expensive.  Just needs plenty of patience and work through the wet&dry papers, then diamond pastes to get the final polish.  Mine took about 4 hours in total so maybe not cost effective for a pro.
I got about halfway through and decided that as it was a nice sunny day (1 one we had last year) I would continue on the patio.  You guessed it, just about to give it a final polish when I dropped it, and yes it broke into 3 pieces.  I nearly cried !!
Just had to cough up for a new one but settled for a Sternkraus which was a perfect fit.
Edited by canthus
I have polished one yesterday, no big dial. Speed can be 6 - 10K, doesn't matter much, paper quality do matter. I've found that most effective is 3M 600 grit, wet of course. Finish with 2000 and if you have it diamantine paste.
One or two darn specs of dust have dodged my attention and I'll remove them tomorrow.
Did you use a Drumel tool and some sort of bit?
Rotation speeds implies a rotary tool of your liking and wet paper about 6cm diameter. People saying it can be done manually just love to see their life being ground slowly.
Edited by jdm
Thank you very much jdm. I did it going from a 240 grit drumel to get rid of the big scratches, down to red polish and over to 1200 grit by hand and finally 2000 grit by hand. c1c57f58154719902c9459bf6d727151.jpg
My wife said I should use Fine 4F Pumice Stone for the final rub to get out any hair line scratches. Thoughts?
If you had kept going with the 2000 grit before the final polish you would have removed all the marks from the 240.
I did finish with the 2000 grit but did a final buff with Peek. I think a piece of leather would work as the final final buff
I did see some very fine scratches if I looked at a light through the Crystal. I'm pretty picky so I did do a rebuff with the drumel and some fine Green #7 polish. Looks pretty good now. Like new. Now I don't have to disassemble the Crystal assemble including Gaskets etc.
Awesome video dude!! Exactly what I was looking for in terms of polishing info!
Thank You
Hey thanks. The video I did is what I was looking for all along. I have a ton on YouTube music and some magic videos but now am adding Watch Repair instruction where I can and only if it works. Mark is the man when it comes to the watch repair game. I am one step below amateur. You can find me on Facebook as well under JDWatchboy. I put up the site to track progress on some watches I am fixing for friends and for part costs only. Just enjoying the hobby, but who knows?
Here is the video I put on YouTube with the technique.
Thank you jdrichard ,i watched the link just now. good sharing. you have done a good job.
Thank you, just giving back[emoji1]
Ok, revised advice. I took the Crystal once again as there were two small hairline scratches that were just bugging me, and tried to remove them using pumice. That made it worse. Then I used my drumel again and tried to buff out the new scratches; that didn't work. Then I got out the 1200 grit and worked a full sheet of rubbing followed by the 2000 grit and a half sheet of rubbing; THAT WORKED! So new technique should be Drumel with 240 grit drum for the first shooting and major scratches followed by a quick drumel buff with number 6 High Gloss, followed by 1200 grit, Two Sheets of hand rubbing and 2000 Grit 1 sheet of hand rubbing (sanding). DO NOT GO IN CIRCLES while rubbing; back and forth is best. Thanks.c57d3bc465bd728e67c60a8688664877.jpgc80a5f8af13ad56d65617b4a571299ad.jpg
Hi Richard,
What dremel model do you recommend for this job? I have an old one with only a 2 speed control...
Thanks,
Bob
i gotta tell you that is an excellent job. it looks like a new crystal. i just purchased a seiko diver that needs a lot of help with the crystal. i am actually gonna buy a new one, but i'd be interested in trying this method on this crystal. the diver i got has quite a few deep scratches that i think might not polish out.
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
