Balance Wheel
Hello, can anyone tell me why my balance wheel hole is bigger than the staff replacement that is for that balance. I was trying to fit it with a staffing tool but could not get it to make a rivet on the wheel.
  • Similar Content
    • Back home...printing now.  Will report results
