Eta 2824-2 Stem Release Pusher Stuck
Flo
Hi everyone,
I'm new to this forum, and I'm looking for help!
I'm facing this problem : while fixing the dislodged keyless works on my ETA 2824-2 (seems like a classic issue, from what I've read), I pushed the stem release pusher too far and it wouldn't come up again, it is stuck under, probably dislodged...
Do you guys have an idea on how to fix that ?
Thank you in advance !
All right, thank you Gingerr6.
The piece that I need to access is the setting lever (443/1), right ?
I access it from the front of the movement, by taking off the screw for combined setting lever jumper (5445), then the combined setting lever jumper (445/2), and then the yoke (435), is that correct ?
IMHO, it is best to, once you remove part 5445, check what you find...
you may have to simply reset the whole thing but if there is something broken or bent then you may need to replace or fix accordingly.
Cheers,
Bob
PS. Welcome aboard!
If you dont want to take the dial side off, didnt mark have a clever way of accessing the key less works without dial disassembly somewhere in one of his videos?
Edited by jnash
I believe you're right I remember seeing it myself Mark removed the barrel bridge and got to it from there if we are talking about the same video
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
