Watch Hand Press
Davey57
So I assume you use the rodico on the toothpick to hold the hand and then press in in with the press? I would love for you to provide a quick write up and perhaps a few photos showing the technique used. I am new at repairing watched and have two divers completely Refurbed to date and am starting on a Seiko 6139 Auto Chrono that will no doubt need new hands after the clean and restore.16331ef904b24fefabed97f82aceebf1.jpgd8de160bd4f17c3af139402c3779386f.jpg9f825a3521dd7daa8447f7c3d7825b96.jpg
I can't do any pikkies right now as I'm up in Singapore for a few days. However what I do is sort of Mount a blob of elongated rodico (not too big) on the end of a toothpick or preferably a longer piece of pegwood. Lay the hand face up on the bench top and press the rodico onto the pointer end, as if it's now an extension of the pegwood parallel to the benchtop. This allows the hand to be picked up and maneuvered at an ideal angle, a bit like using a pencil. Then its just a simple task of transferring it to the already aligned and setup movement in the press. A 5-10 power loupe is the trick here to getting it all aligned nicely, especially those second hands. Real simple and quick.
My experience is that, with a lot of practice hand setting with the hand held hand press tools is usually a smooth process. (but hand setting can at times be the most frustrating and difficult things you can do, at least if you have high standards for how precisely they're set.)
I have the set of 3 from bergeon, just having the singular one doesnt always give you the precision you need, the canon you're pressing the hand on to might be slightly larger or smaller than what you get with the single tool, which causes problems. It helps a lot to have the two other hand press tools.
I've also bought a cheap, indian made hand, bench sitting hand press and wish I hadn't bothered. it gathers dust in the cupboard, so if you are going to get a hand press I'd say be prepared to buy an expensive one for it to be worthwhile.
Edited by Ishima
Regretfully, there is no snap to hand setting!
which brings back my previous comment: if it snap, chances are the pivot or the hand broke or the hand will scratch the dial! :)
I have various hand pressing tools of all shapes and sizes and had some problems with the chrono type hands,  After getting advice from a sagacious forum member I bought a cheap hand press from China that is either a clone of the Horotec one or it is from the same stable and quite frankly it was worth getting.
Cheers,
Vic
Cheers,
Vic
Mine is in the mail. Not sure how the hands are attached to the tool, if they are at all. Could you show a photo of your hand pressing tool?
JD, you have to place the hands onto the pivots. The tool is only used to press the hand on, it does not hold them. The tool allows this to be done with a delicate touch and accuracy.
I use a jewel picker upper to pick up the hands without the fear of scratching them with tweezers. This is a tool with a tacky gel tip. Have a read of this thread for information on the picker upper. http://www.watchrepairtalk.com/topic/1385-best-way-to-pick-up-jewels/?hl=%2Bjewel+%2Bpicker+%2Bupper#entry13144
hello jdrichard,
Here is a pic of what I got, The advice from George is as always sound and he advised me the same thing which I copied - I "borrow" one of my wifes crafting jewel pickers that she used in her cardmaking.
Cheers,
Vic
Failing a jewel picker. A cocktail stick with a bit of rodico on the end will do. If you drop the hand on the dial don't attempt to pick it up with tweezers. I've done it, in my ignorance and damaged a dial and wasn't aware until I held the movement up to the light. Wish I had found this forum earlier. Some great advice from some knowledgeable guy's.
Sent from my SM-G900F using Tapatalk
hello jdrichard,
Cheers,
Vic
This tool is basically what I have coming. Thanks, I will now wait until it arrives before I attempt to put the new hands on the 7548 I just Refurbed. And the 6138 I am in the middle of. Again thanks.
I just purchased 2 picker uppers from cousins uk this morning.
  • 7 years later...
Hello dear forum,
Could anyone with the cheap Indian/Chinese tool please tell me the diameter of the stakes where they are held by the tool?
Talking about this tool:
https://www.cousinsuk.com/product/hand-fitting-press-watch
Why am I asking?
I'm keen on using my Seitz jewelling press for hand setting. In fact, I've used it already a few times with nice success with the Seitz's own steel stakes/punches. Since it's really 100% perpendicular, I didn't cause any damage to hands YET. But, of course, them being hard metal, I am worried that I will eventually cause scratches. Now the idea: I want to buy only the hand fitting stakes from CousinsUK (see at the bottom of the link above) and hope that I can somehow fit them in my Seitz press spindle... But I'd need to know the initial diameter of the stakes. 4mm would be great, hahaha!
Shout out especially to @jdrichard @Bimroy @Ishima @Vich who mentioned having the cheap tool. Thank you!
    • I wish to share my experience with thyme tea with everyone. Six months ago when I had my second bout of Covid, my chest was so congested that breathing deeply hurt. Coughing was pure agony. And with a 40°C fever that comes back every 6 hours when the level of paracetamol in the blood falls, I was willing to try anything.  Then I saw this video on YouTube and I decided to give it try. I drank a cup of the stuff and went back to bed. When I woke up about an hour later, I coughed up a golf ball sized lump of greenish-yellow phlegm. And almost immediately, all symptoms suddenly abated. 24hrs later, I was feeling perfectly fine. I repeated an ART test and it was negative. I started recommending it to some of my friends and many of them found it useful, although some claimed it had no effect. I had another round of Covid last week. I tested positive on Thursday and although the symptoms were very mild, I drank a cup of thyme tea just to play safe. And by Friday evening all symptoms were gone. I repeated an ART test and it was negative. If any of you read this, try it out the next time you get Covid or the flu. Let me know your experience with thyme tea. @watchweasol, you might like to take note of this.
    • The problem is where the arrow shows.
    • Why is it when that little voice says, "This is a bad idea," we always want to talk ourselves out of it? I had the low blood sugar jitters earlier, but insisted to myself that I'd be able to oil an especially tiny cap jewel on my friend's Omega 1001. With lots of concentration, I nailed it. But when I put the hole jewel on top, it was too much oil and it squoze out everywhere. It didn't spread on the cap jewel much thanks to the epliame I'd applied, so it was more than it looked like from the top. Back in the cleaner, dried, re-epilamed, dried. Time for a second try, but now I was more shaky even than the first time. "This is a bad idea," my brain told me. "Take a hike, brain," I said as I watched the oiler jiggle into my microscope's frame. And just like that, the jewel was a tiddlywink and flew out of sight in the blink of an eye. With a strong UV flashlight and the waste of a lot of time I did find it on my desk, but that's some stress I didn't need in my day. So friends, listen to your body, and listen to your brain when it tells you now's not the time for precision work.
    • I dont think Hector means there is an issue with the hairspring at the collet, only that the collet is not centered over the jewel hole. You can check this by unmounting the hairspring from the balance and recentering the collet with the balance jewel. If the coils remain undisturbed then i believe it unnecessary to dismount the collet and only adjustment at the stud is needed to bring the hairspring to shape. If any of coils have been accidentally bent then reshaping of hairspring separately would be required.
    • @HectorLooi Thanks.  I do have a microscope. But no camera to show what I see in it.  You are correct that some coils overlap. In particular the outside one where thr regulator pins go  overlaps the previous one. I will try your suggestion.  I am surprised that there is an issue with the collet as I don’t see how I would have messed that up.  I didn’t think the impulse jewel is damaged as I can check it in the microscope. I meant that when I put the balance I am always wondering if I managed to set it correctly in relation to the fork.  Thank you all. So I think I will take @HectorLooi advice and note that the hairspring needs fixing and go practice with my second ST36. In any case this one also has the setting lever screw broken in the setting lever.  I think I’ll also order a dial, case, hands and strap to make a watch out of that second movement.  I see a bunch of them on AliExpress or eBay.  Anybody has recommendations?
