New Member From New Jersey
Timezone
Hello from me. There is someone on here who has just signed up for a Timezone class. I'm retired from all this stuff now but I still like to give a hand.
Thanks for the warm welcome.  I'm just a newbie so I need a lot of help.  Hope to hear from you again.
Rich
(Timezone)
Hey, greetings!
I am also slowly moving through the timezone watch school, and having a good time, too!
DavidS
Hi David:   Thanks for the greeting and perhaps see you on the TimeZone forum also.  Good luck with the course.  I started in January and I'm enjoying working on my 6497-1 movement.
Rich
Timezone
Rich
Timezone
Just put up my "finished with level one" post, and am on to level two!
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
