Broken Mainspring Screw
avkxyz
It is more than likely that the price of the arbor + shipping will way exceed the value of the watch.
If it is a customer's watch (ie you are repairing and charging money) the cost will make them say 'don't bother' and the watch will remain unfixed.
If it is yours then chuck it in your drawer but keep your eye open for an organ donor.
If you still want to try to get the broken piece out - try heating it, then gripping the visible end with a sharp, thin cutting tool and turning. (i have used nail-clippers to good effect as the blade portion is narrow in width but sharp. Side cutters are usually too clumsy for this application.
HTH
Anil
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
