Vintage Look, Modern Size
DJW
Here is another build I just finished. This one I WILL keep and be wearing often!
I like vintage watches but not the usual small size, so I tried to build a watch that had a real vintage feel but had the overall size that I find appealing. It measures 44mm, not including the crown. I think it captures that feel!
Yes, the strap is too small and will be replaced later...
Edited by DJW
Lol. You keep nearly all your watches Don :D
I love this cushion shape. I have to say I think it is your best to date (dial paintings notwithstanding).
  • 2 months later...
Hello :
Taking this opportunity to join in thru this thread... hoping to learn and contribute to the forum. Im an active forum member of PWC (philippine watch club) but lately Ive been taking my interest over "customising" and restoring vintage pieces..
My question - how do I post pics?  :thumbsu:
Cheers
Jay
Got It...(Before & after shots)...TFL (Thanks for looking)
  • 5 months later...
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
