Hello From Texas
dferrier
Hi all, I have recently (in fact the last couple of months) gotten bitten by the horology bug.
I have traditionally been the kind of person who after putting on a watch never (and I mean never) took it back off. It stayed on swimming, showering, whatever until it stopped working. I used to buy the old Casios with the 7 year batteries just so I would not be bothered to replace the battery. When it went so did the watch. :)
And then I started running a lot and got a Garmin GPS watch which I had to charge up about every week or so. Well that was fine, I was using it to track runs but it stayed on my wrist just like all the other watches (and by the way I couldn't tell you what happened to all those old watches...). I guess they got scavenged by the watch gnomes or something. I never threw them away, they just went away...
So fast forward back to around November last year when my wife showed interest in one of those smart watches that track everything about you and you can change the watch faces etc... So since I am always trying to figure out what to get her for Christmas I started doing a lot of research on the different ones. Well not to bore you with a lot of details, while googling this and that, I started catching some things about real watches, not just the ones you have to put on a charger every night.
And I decided I had had enough of the electronic stuff and so gave myself a Christmas present. I got an Orient automatic all black. Really nice watch off Amazon but although I could tell time, I couldn't read the date because it had this tiny little dial with the days of the month... And my eyes are getting aged like the rest of me. So I sent it back yesterday. I was sad but there it is... I am now going to stick to watches I can at least read while wearing for my daily driver so to speak...
Well in the meantime I ran across the term Tourbillon and then I was really hooked. That little rotating cage with the hair spring rotating back and forth, well I thought I had to have one of those so I ordered what was labeled a tourbillon watch by Forsining for $35 dollars off Amazon. I thought what the heck for that small amount of money, its worth the risk.
Well as you are probably guessing, it was not a tourbillon. It is a nice looking watch and keeps decent time but certainly not a tourbillon.
And I am watching a lot of the chinese tourbillons on ebay but they all seem to start at $5 dollars and end up selling for 900 or 1000 dollars... Oh well, I don't want one *that* bad... :)
I went from practically ignoring watches, to researching how to work on and repair watches. Crazy I know. And I am already buying used stuff off of ebay and planning on changing out cracked crystals and so forth on these used watches.
As they say, I've got it bad...
Pics of the cheap watch...
post-1710-0-56110000-1452200793_thumb.jp
post-1710-0-87191500-1452200799_thumb.jp
  • 3 months later...
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
