Thanks for the info. I need to replace the crown and prevent it from coming off the stem once I get a new one. What’s the best approach to matching the new stem to the existing watch?
I assume you mean the bridge where the centre seconds pivot sits? If so, the pivot may sit slightly below the bridge surface, especially if in a jewel. In which case you need a more pointed tool which actually sits on the end of the pivot. Hence my post above about using jewelling/staking stumps.
What's the purpose of the slot in the bought one? -
By rossjackson01 · Posted
That all? Plastic pill top, small screw through centre. Made.
