Hi guys, is there a watchmakers guide to what tweezer's you should use for watch repairs? Or what the tweezer numbers mean? [emoji45]
Dumont set a "standard" with their numbering, which other makers copy or use together with their own. You can check these on any website that sells them.
No. 3 is the "general purpose" one, I have one and works good actually even a bit broader tips one would no.
I also have No. 5 for manipulating (in my case, finishing destroying) hairsprings.
I was thinking getting an angled tips one because there are a lot of situations where I find myself working impossible angles, but all in all as a beginner a No. 3 is all what you need.
Thanks for you're advice mate! What size of tweezer's would you use for setting watch hands?
No. 3 is OK for large hands, for smaller ones use Rodico.
As always, I'm only saying what works or it's easier for me. Others may be able to keep minuscule hands or other objects in position with any type of tweezers, I don't doubt.
I use no. 5 for most everything -- actually two no. 5's -- but also have a wide tip No. 2 for "heavy" stuff. I dress the tips often (which is key) and have found some use for a No. 3. Whatever you find that works for you is OK, just don't forget that regardless, tips need to be dressed and maintained.
My brand of preference is Dumont and they make different versions of the same number at different prices. It all depend of the material and other -- not so evident -- features. I believe some other name brands might be just rebranding Dumont's or simply trying to imitate it. Still, Horotec has good tweezers (that I've tried, their aluminum tweezers suck) but Bergeon I haven't tried yet...
Cheers,
Bob
I use Dumont 4 for general, and 5 for fine work, as to hands, I use boxwood tipped, or carbon tipped tweezers too handle these, removes the risk of scratching.
Yes, carbon tweezers I use too! (Sorry, I'm not Yoda). I use them for hands and for batteries since I find the plastic battery ones a little awkward for my style...but not the Horotec aluminum ones!
What carbon tweezer's would you recommend getting, I've looked at a few different makes but the tips look abit too fat? I don't want to be something that's not right?
I think vestus (spelling?) is ok in carbon tipped. They have different "fatnesses" at the tip. Check out ofrei and/or cousinsUK. Even Horotec if they are not aluminum, make sure of it. For me, aluminum is not "springy" enough.
I have misplaced my dumont 2A . So i orded a new from Ofrei the other day? they had a sale. Costing only $18 . Love the rounded tip for removing stuff like bridges and such. Great when you disassemble a movement . When i put the movement together again i normally use a dumont dumoflex 5  or vetus 5 . Have a bambu vetus for battery replacement . Not so good but it works . Seen some whole carbon tweezers from Bergeon on Ebay . Doesn't carbon conduct electricity?
Edited by rogart63
For setting watch hands, I have a personal rule: nothing made of metal touches dials or hands. Ever. Rodico, boxwood, Jewel-picker-uppers etc...
X2 :)
    • Hi All, I’m having a hard time finding a balance assembly or even a working donor movement for a Gruen 330.  Any leads appreciated.   Gruen doesn’t stamp the caliber number of the movement but lust in the case back.
    • Why do you think this is Fontainemelon ?  The balance staff you will need to source separately.  But first it's important to accurately identify what you have there. Research Ebauches Sa, see who was in group, to find the brand that made this movement.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
