3 hours ago, RichardHarris123 said:
@oldhippy, hasn't been on since the 14th of April, I messaged him nine days ago, no reply.  I  hope he's on an around the world trip with endless booze and supermodels.
joking apart, I  hope he's alright. Does anyone know anything?
  • Sad 2
I know he had indicated that he would like to retire. But it's always sad when people just disappear off the message board and we don't know why.
then I was looking at his profile I wonder if that really is his birth date? In this day and age is always concerning if your birth date is out there along with any other personal information. Then I went to his profile for this Devon England. It seems like the moderators and other people in the UK could get together from time to time. or perhaps the moderators should have communications beyond this message board like maybe a phone number or a physical address jesting case things break down you could reach out the somebody.
that would mean that if the moderator is concerned about another moderator you can at least investigate as to they just disappeared or never seen again.
  • Like 5
8 hours ago, Neverenoughwatches said:
 Over the years  I have been here , have seen few  members  quit,  but always come back.
I received this, forwarded by @Klassiker, from OH
 have torn muscles in my right shoulder. I have not been able to use my pc because of the pane I'm on very strong painkillers and spent a little time in hospital. Could you let the other mods know. Thanks.
  • Like 5
That good to know in one way.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
