Crystal Tool?
chadders1966
Hi
I've noticed this item on EBay Germany (http://www.ebay.de/itm/UHRMACHER-WERKZEUGE-STERNKREUZ-GLASER-EINPRESSVORRICHTUNG-FUR-ARMBANDUHREN-/381390755107?hash=item58cca91523:g:9O4AAOSwd0BV7G7i). I've seen one or two of these for sale before and can't figure out how they are used. My best guess is that rather than press on the crystal to insert you place the appropriate die over it and press on that instead, but like I say it's just a guess and there is nothing to press with unless that small tool is it. Anyone know how to use it? I'm just curious.
Stephen
UPDATE
Well, I ended up buying it anyway - I have a weakness for old tools ;). I'm still no nearer understanding what it's for or how it's used though. This is what it looks like:
The box and tool are labelled Sternkreuz, there is a number on the tool but I can't find anything on it. The box contains a lot of aluminium dies as follows:
Each one is marked Glasrand-0 with two consecutive mm sizes, and they cover from 170 to 369. The aperture is slightly less than the smaller of the sizes. Also in the box is a tool with two metal jaws with grooves on the top. The jaws open out to a maximum of 370mm:
The other item is made of what looks like acrylic material. The two pieces fit together, and one is shaped so that the dies fit in. They can fit in either way round:
I'm a bit puzzled as to what it's use will be. I presumed, given that it is Sternkreuz and the shape of the dies, that it would be for glass fitting, but I can't see how either of the items with it would work for that. The jaws on the tool are quite small and sharp, would probably damage a crystal, and then there is the groove on top. The acrylic block is obviously shaped to fit the dies, but again I can't see the purpose.
I thought I'd ask here, see if anybody has any clues. I might also contact Sternkreuz and see if they know. Thanks.
Stephen
Interesting suggestion about factory gauge, not something I had considered. It has the look of a consumer item to me, but I haven't been able to think of any possible use for it.
I was going to contact them, but there doesn't seem to be the facility to send documents. I'm not sure I could explain what I was asking without photographs.
Just send them a link to this thread.
  • 4 months later...
Well I finally got my answer, courtesy of someone on EBay selling one and including a photocopy of the instructions in the listing. I've just spent a while translating from German and it is a set for inserting armoured crystals - very interesting!
Stephen
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
