~Hello
mwilkes
Hi folks - I'm new to the forum. Currently doing BHI's distance learning course in clock/watch servicing/repair. Today, and most other days, I'm wearing a Junghans Chronoscope - it's big and fat, but I love the simplicity. Tasty customized Valjoux 7750 movement under the hood too...
That is the type of watch that I LOVE! Kind of a retro thing goin on! Although, I was also amazed that it was only listed as 40mm diameter....It plays a lot larger than that with such a thin bezel, Well Done! And, compared to a fair number of watches out there, $2K seems like a pretty fair price, just sayin...
    • Thought I had to share this - last time I cleaned out a deep fat fryer there was less mess than this. Another pin pallet movement. Unsurprisingly dunking it in Castrol GTX didn't fix the broken mainspring which is the only issue I've found.    Any tips for the dial? Also covered in oil.
    • Hi Nev . No i didn't try this balance in the movement as it didn't run and the deformed staff broke when i removed the roller. Problem is what i think is the correct staff for this movement, the hub seat, roller and collet profiles are all too small for those parts of the assembly. The movement listed on Ranfft's site is correct my movement and the nos staffs i have match the ronda measurements. I can only assume that the wheel , roller and collet openings have all been broached to make them fit an oversized staff, both staff pivots had also been modified.
    • Yes, threw it on the demagnetizer before I cleaned it to be sure.  This picture doesn't show it well, but I can definitely see liquid where the turns meet up.
    • My newest 404 candidate, a late '60's / early '70's Waltham with a UTC 33 / Seiko 6601 17 jewel automatic movement. It needed a new crystal and I put on a strap from my Strap Graveyard. The timegrapher was a snow storm before servicing but it cleaned up nicely. I really like the funky font used for the hour markers.
    • Hi Rich, the main problem with the balance is if the roller is from this movement. Did Yoy try if the balance interacted correctly with the lever? You can use suitable (by size) balance/hairspring couple from You pile of balances, but the roller must be for this lever (original for the calibre). Not that making roller is impossible, but it is easier to have one.
