I suppose OH referred to adjusting the self adjusting beat feature?
Else 10 deg as amplitude would be much too much here, as I mentioned above.
Frank
One of the problems with the original question is there a way way too many variables here. For some clocks the pendulum barely moves back and forth and that is it acceptable amplitude for that clock. Other clocks have wild swinging pendulum's practically bumping into the edge of the case and for that that's the acceptable amplitude.
There are so many factors to take into consideration it is impossible to give a correct answer, a dirty movement will give poor amplitude the same if it is dry or the wrong oil, I won't bore with anymore.
18 minutes ago, Nucejoe said:
 Hey guys, just googled for adjusting  clock beat.
There are more relevent articles on web than Walt Disney bul shi .
Yes its a minefield
14 hours ago, Kalanag said:
My clock has a Graham escapement and is weight driven. Does that mean that a low amplitude is preferable?
https://www.watchrepairtalk.com/topic/22546
Well, it is weight driven and with Graham escapement. This means no problems with isocronism at all, as the torque is constant and the escapement is isochronous by itself. So adjust the escapement for minimal but reliable drop lock and see what the amplitude will be. Don't forget to lubricate the pallets.
PS There is specific behavior of the Graham escapement when changing the depth.
If the escapement is shallow (no drop lock), then it behaves as recoil escapement and the amplitude rises and frequency decreases with the depth increasing.
When the point is reached when drop lock is present, then amplitude and frequency will not any more depend on the depth increasing.  But there will come a point where the depth is so big that the mowement will be not able to work any more.
2 hours ago, nevenbekriev said:
Well, it is weight driven and with Graham escapement. This means no problems with isocronism at all, as the torque is constant and the escapement is isochronous by itself. So adjust the escapement for minimal but reliable drop lock and see what the amplitude will be...
That perfectly answers my question! Thank you @nevenbekriev!
I wondered why the clock is equipped with 2 weights of 2kg each. It obviously increases friction, amplitude and lock angle for nothing.
Edited by Kalanag
And it depends on the „reserve“ the manufacturer calculates for increased friction due to lack of service.
With half the amount of weight my clock runs still perfectly. The drop takes place at the „I“ index and the swing of the pendulum ends half way between „I“ and „II“. That is in line with the comments of @praezis and @nevenbekriev.
Edited by Kalanag
If you showed us the movement that would have helped. For example if it has maintaining power that will make a considerable difference, are the pivot holes jewelled yes or no or partly as that jewels cause less friction.
Edited by oldhippy
On 8/19/2024 at 8:54 PM, oldhippy said:
Its more technical these days you have computers that design the movements ok humans have the input, but they couldn’t make the parts by hand using the tools of say 150 years ago.
Yep. I started my working career as a CNC machine tool programmer, not for watch or clock parts but for all manner of components, including aircraft parts.  Of course, I wouldn't have the same level of competence on 150-year-old tools compared to my CNC skillset, but that's only because those skills are no longer needed with modern techniques so you have no reason to practice them.  Some things are very similar, such as working out how to best hold a piece of material to machine it accurately, etc., or understanding how a cutting tool performs on a specific material type.  Watch and clock parts follow the same principles; they're just smaller.  I found that, while a computer can be used to design and machine a part, you still need the same level of engineering experience in the designer/operator to drive that process.  Machines allow very precise tool positioning and complex movement patterns, but it still requires a skilled programmer/operator to ensure the finished part comes out as you expect, taking into account tool wear, material flexing etc.
Where the old methods come in very handy, especially in this trade, is when you only need to repair or make one item.  If I'm manufacturing 200,000 of something, then CNC wins every time.  If I need one, manual hands-on is probably quicker if you have the skills and tools available.
Edited by MikeEll
How good are 3D scanners these days?  Could a part be scanned and only minimal adjustments made to the programme?
When it comes to clocks that have been handmade and are of considerable value and parts need to be replaced they should and are normally made by hand in the traditional way without machines.
scanners are really good, especially if you're scanning a part with curved surfaces etc.  On a simple part though its often not necessary to scan as you have the dimensional data available either manually, or as part of a 2D drawing or 3D model.  Its more common to use scanning to produce a model, then the model used to extract the necessary machining data.
or a combination of both.
For example, if making a number of parts to different dimensions, such as shafts, toothed wheels etc, the CNC programs can be parameterised. You might supply the various dimensions for number of teeth, outside diameter etc, and the part pops out the end without much/any programming effort each time.
Edited by MikeEll
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
