25 minutes ago, LittleWatchShop said:
I don't see any other mistakes.
Should I add this capacitor also?  I didn't think I needed it.  It wasn't on the original schematic, I had added it because the data sheet for the rail splitter showed it....
35 minutes ago, LittleWatchShop said:
You never fixed this issue and I missed on subsequent reviews
I followed the schematic below....  Supposedly he got it working like this....  It is a LT1115 and he is using it as a buffer not amplifying with it.  The rest of the OP amps are 5534s.  This schematic is from a previous post several pages back...  It is a modified version of the watchOscope one.  (Which I did make last week)  I am making several difference ones to see what works best.  I am using a modified microset as a preamp right now in my diy setup which works quite well.
1 is not equal to 2.  Go back and carefully look at the datasheets for these parts and look at your schematic.
There is a major error in the schematic, it will never work this way ? :
negative supply pins are connected to +4.5 V and +inputs of NE5534 are connected to 0 V!!
Another question, to what input are you planning to connect your preamp? Will it bear an output signal of 0.75 to 75 V_peak (theoretical - there will be clipping of course)? For what do you need that ambitious amplification of 7500x ?
Frank
Frank
Thank you...  Please tell me how to fix.  Looks like I have 9v at neg supply.  image.png.2c4a6a55c87f28bcf242ae7de0461a6a.png
UpdatedOpAmp.TSC
In fact you have. I wonder if you already blew your ICs?
You should connect:
+9V to V+ pins
0V to V- pins
4.5V (TLE2426) to +In pins.
...and think about my 2nd question.
Frank
Edited by praezis
  • Similar Content
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
