I'd prefer not get them from a file-sharing site, as many of these install malware. The fact that it didn't work for ligangyi suggests that you may have the permissions set on the attachments such that only you can access them. I'll send you a PM and give you my e-mail address and you can mail them to me.
I received the samples you e-mailed me, and they sound fine. The noise levels are certainly not a problem for analysis of the signals. Most of that noise comes from the amplifier itself. Any resistor produces noise proportional to its resistance, so the noise produced by the earliest stages of amplification becomes amplified by the later stages.
Great then, I am glad to hear that!
I will try to improve the watch - sensor coupling, and to improve the ambient noise reduction.
Thank you!
Bogdan
You can download the File from the download site if you pay attention and perhaps are lucky and depending on how your browser handles files for downloading.  So unchecked the box that you want to install the download manager. Then I ignored the warning that I needed to install another plug-in which you don't. Two separate download buttons the gray button actually downloads the zipped file. The black button attempts to download the zipped file disguised as the download manager In other words a exe Which is definitely not what you want.
I give you shielded the pickup it would help quite a bit for the background White noise.
The Watch-O-Scope software is now available for general downloading. This is version 1.0 Beta 2. All features are available for a period of 60 days from first use or from release of the final version, whichever is later. After the evaluation period, it reverts to a "Lite" mode where some of the more advanced features useful to professional watchmakers are disabled.
http://www.watchoscope.com
This is really nice. I read the whole thread with great interest, since I still do not own a timing machine, and I only can find chinese branded ones on eBay for the budget I can dedicate to it. I used until now my cheapo-tablet with an android app, and eve if it is not extremely precise, it gets the job done (at least for a hobby watchmaker like myself). I was aware right from the start that the mic on this tablet was not the "best", so I was looking at a DIY solution, and found this project here. I do not posses the necessary soldering skills to build it, though, after going through all the pics in this thread, so I am looking to get the "pro" version, whenever you make it available.
Hello!
First of all, congratulations on the Beta version!
Second, I compared the noise from the first amplifier with the one from the second, and I think that there is an improvement (on the second one). What I did was I short circuited the piezo and what was left was the noise (@JohnR725: this is why I doubt using a shielded cable would improve the signal to noise ratio, though the downside would be that it would make the cable stiffer and so the sensor would pick up more ambient noise (table movement, etc). Indeed if I use the charger on the laptop, the noise increases (with the mains noise - 50Hz and some harmonics) but otherwise it is ok.
Third, and most important, I tried the application and it works great! I would call it "plug and play". The best thing about it, in my opinion, is the long term analysis. It's also very nice it shows you the waveform also - I couldn't manually set the threshold, but also I didn't read the manual (RTFM :)) I don't know what to say about the sound card clock jitter compensation, but I think that on the long term analysis it doesn't matter too much.
Here are some pictures with a 2893-2 base movement (only the train and the escapement) and its behaviour in the app. Take into consideration that it is an uncleaned donor-intended movement:
the waveform:
the short-term behaviour:
the long term behaviour ( for a short term :) ):
Again, a big Thank you, Stefan, and Great Work!
Bogdan
Glad to hear it's working for you!
To manually set the threshold, you have to enable that option in the settings window.
As far as sound card rate goes, it's not jitter that is being corrected for, but the overall average rate of the card. You really should calibrate Watch-O-Scope by manually setting the rate to 3600, and putting a known-to-be-reasonably-accurate quartz watch on the microphone for a few minutes. Any reported rate error can then be corrected in the settings window.
Stefan
After seeing Mark's great video tour of his new workshop, I am now contemplating dusting off an old Windows laptop to use as a timegrapher, just need to find out from Mark the wiring for the microphone now, and how it connects up to the laptop.
I'm making your first amp as described. After I get that working, I am going to see if I can do it with a FPGA (Field Programmable Gate Array - about 1 million logic circuits), and a fourier transformation to provide accurate beat analysis. :D
So install the software on a netbook which has a minor problem of the screen is too small and toolbar on the bottom covers up the very bottom of the screen. I think there’s a way of making the toolbar disappear I just haven’t had time to look into that. So left everything on default other than changing the lift angle for the particular watch I was timing. So outstanding that the software is out to play with.
Then there have been other Windows-based timing machines in the past none of which worked very well so I made this amplifier to play with the other software. So this is a dual op amp design with a little bit of filtering.
Thanks for sharing your experiences John.
As far as the window size goes, I specifically made it 1024x600 so as to fit on common netbooks screens, but I had forgotten that not everyone runs their netbooks with the taskbar hidden (I do just because there's so little screen real estate to begin with).
Is that Windows 8? If so, you're the first person (that I know of) to try my program on Windows 8. I figured it would work, since the program doesn't do anything non-Microsoft-kosher, but it's good to see confirmation.
Here's how you hide the taskbar in Windows 8:
  1. Open Taskbar and Start Menu Properties by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
  2. Clear the Lock the taskbar check box.
  3. Select the Auto-hide the taskbar check box.
That amplifier looks like it might be similar to my original dual op-amp version in terms of general architecture (mine was certainly not the first amplifier to be designed in that way).
Edited by svorkoetter
Just for giggles I thought I would try it on my MAC and it seems to work fine. I am extremely impressed!
Wow! I would not have expected that to work. What software are you using to run Windows applications on the Mac?
@JohnR725: Hello! Could you please share the schematics? I see you have a very good signal-to-noise ratio in your watch-o-scope waveform.
It might also be because you have a very strong-ticking watch :)
Thank you!
Bogdan
Another update. Both the microphone and amplifier construction articles are now complete. They're still a little rough, and I'll tweak them as time permits. If you see anything glaringly wrong or confusing (especially those of you that have already built the amplifier from my earlier posts), please let me know.
Building a Microphone Stand
Building a Microphone Amplifier
Stefan
  • Similar Content
    • just a reminder about this test is it's not a perfect test it's a quick test. In other words you can adjust the banking pins that are both the same and visually this test will pass everything looks the same but both banking pins can be in the wrong place. although the majority of time when people are playing with banking pins I don't put them in the same place. one of things have to be careful of is I believe some of the pallet fork measuring tools that actually give you the roller jewel size are actually size so that I get confused? What I mean by this is if you inserted a whatever size in and are always told to go a slightly smaller I thought that the gauge itself its number corresponded to give you the exact number. So a lot of it depends upon the gauge itself I think you do want the roller jewel slightly smaller because it does have to fit in the slot and it does have a little bit a play. But if it's too small you will lose energy so does have to be sized right. Oh other things to check is? I'm attaching an Elgin sheet on checking the escapement I've seen references in the past to making sure that the slot in the four corn is nice and smooth and apparently you can end up with a rough slot and then the recommendation is to polisher clean that up. Not sure how well that's really going to work even if it has been the recommendation of other reference materials. yes art full plate watches fun when they don't work. This is where it's nice to have another set of eyes sometimes as maybe they'll find something you didn't  although that can add other issues. The owner of the shop provides himself on his skills of so now two of my watches have relocated to his bench to solve problems both real and imaginary I'm sure that will get fixed eventually hopefully. But still sometimes another set of eyes might see something that you're not. yes this sort of thing can be quite frustrating. Also makes for an interesting problem unless of course you're the one trying to solve the problem that it's a Escapement Elgin setting up the escapement.PDF
    • I’m not to sure mate! I’ve sent a picture! The crown is off a Tissot 1853 automatic limited edition T115427 A GP19 moto go watch!
    • For years and I'm still using it I've been using something called SeaMonkey? It's a Mozilla product Basically outscore its Firefox plus an integrated email program. But not the same problems here a lot of times when things are upgraded they tend to be now aimed at very specific browsers like Firefox so I've had to switch to Firefox to respond to any of the messages on the group. So yes they do seem to be getting more browser specific and that may be a reason for others having complications especially if whatever you using hasn't been updated. So yes the world is getting more browser specific perhaps for security reasons. Even though I use a product that is updated on a regular basis is still has problems. So whatever you using for browser should be up to date and if is not recognized it's going to be a problem.
    • I did remember to ask at work and minor complication? Well I suppose technically two separate complications. First off glass mineral glass versus Seiko's Hardlex Glass. Don't know if other companies have their own class or not and a basic class for crystals is probably not the same as window glass it would be more transparent. It becomes obvious if you're looking at a sheet of flat crystal glass versus window glass it's definitely more transparent you can see it when you look at the edges of it window glass looks green. No idea how that changes physical characteristics other than optical. Then we also have thickness like the Seiko five's there crystals are really sick compared to other things and I'm guessing that makes things different. In the first link it talks about Sapphire versus mineral glass. One other thing is bothering me though when I'm reading this is where is the source material? What I mean by this is could we end up with multiple generations of salespeople quoting the same sales tactic or information and we don't actually know because you don't have a source reference? Let me quote something off the website it's brittle oh dear I was sad? Except it's not immune to damage it can crack where shatter under extreme force or impact. So what is the definition of extreme force or impact? Then is that more or less extreme then mineral glass?  Then regarding the price difference while back I had asked the owner where the Sapphire came from and basically wherever he can get the cheapest. So typically ordered from a variety of online supply watch parts in the US and  aliexpress China.. Then yes it does make a difference because we go through a lot of glass crystals and sapphire https://thehorologylab.com/sapphire-crystal-vs-mineral-glass-which-is-best-for-your-watch#google_vignette Then I guess one is glass not glass when it goes by another name? Hardlex Looks like it's purely a Seiko product but now I wonder if other watch companies have their own special glass? I didn't remember from past experience my favorite was people exposed to welding you can find little blobs a metal stuck to the watch case the crystal still intact but there's little burnt holes were bits of metal had actually burnt into the crystal but it was still there. Okay website below starts off with Sapphire sounds good but Apparently it can shatter easier then Hardlex. https://theslenderwrist.com/hardlex-crystal/ One other thing is what I'm reading to websites would be back to I want to see the test results? Often times weren't looking for a subject will find websites where I basically called them these are better than that by the way but sometimes I'll find websites that I will call book review websites were basically the review other websites other material and don't really introduce anything new to the subject. As I said these websites look quite nice which is why I'm giving you a link but where's the test results the definition of extreme how extreme to break a sapphire versus a glass or Hardlex?
    • What browser are you using Rich? Fine for me using Chrome
