Tissot 784 Hairspring not centered
Looks like it is best right at the stud, you could try fixing it, but it's delicate work and even the experienced amongst us don't look forward to working on hair springs.
It's bent right where it passes through the regulator. There is probably a distinct bend there. Bring it back so the regulation curve is uniform again and you will be close, do the final adjustment in the watch.
If you go on you tube and and type in Chronoglide watchmakers next to where it says store you can search what video you want, type in repair balance spring, and you will see 3 videos how to do it, i think its the 3rd one which you might interest you, but i would watch all 3
18 minutes ago, tellemsoulja said:
Thanks for fast answers! Have I correctly marked the spot Nickelsilver mentioned? Bending it "inwards"?
Yes, there. It should be a smooth curve along the path of the regulator.
It is pinned to the studd, thow not seen well on the picture.
OP, may be for You will be easier to open the regulator and untighten the studd carier screw, then put the balance with the hairspring out. Of course, the spring can be reshaped without this disassembly,  but it will be more clear for You where to work on when it is out.
3 hours ago, tellemsoulja said:
The hairspring to my Tissot 784 is not centered, probably messed it up in the cleaning process. Is the hairspring bent or maybe something with the stud? Thanks!
How did you clean the balance assembly, by hand? If you clean the balance and mainplate together, so the balance is mounted on the mainplate, this wouldn't happen, unless you're prodding with a brush if it is hand cleaned.
Funnily enough, my students have just spent the last three weeks learning how to manipulate hairsprings and shaping end-curves, first by working on clock hairsprings, then scaling it down to ETA 6497 hairsprings.
It isn't a bad bend, but I would remove the hairspring from the balance and then lay the hairspring on the underside of the cock then bring the end-curve back to where it should be. It's very important to place the stud in the stud support and tighten with the screw to get it to position properly to give you an idea where the collet will end up once assembled. There is a small groove in the stud that the screw will locate with.
I've taken some photos of a clock mainspring and drawn the underside of the balance for it to position on.
The first pic is the underside of the balance cock (I know the curb pin and boot is quite a gap, but I wanted the pic to be understood well).
The second pic is how the hairspring and end-curve should ideally be with the collet bang on the jewel hole. When the index is moved the hairspring shouldn't be pushed or pulled by the curb pin and boot, or in modern watches the regulator pins. If that happens you'll see a difference in beat error when you move the index arm from fast to slow. You have to make sure there is a gap between the curb pin and boot before you move the index, otherwise it will bend the hairspring, which might have happened in this instance.
The last pic is the hairspring being manipulated to form the end-curve again. This is done away from the cock and then try for shape on the cock remembering to ensure you tighten the stud screw to get the proper position of the spring. I have gripped the spring with No. 7 tweezers and where the arrow is, push the spring until the kink is out and the collet is on the jewel.
If you've never done this type of work before, it's best to try with a scrapper first. It is a lot safer to remove the hairspring from the balance first. I use scalpels to lever the hairspring off, or very fine hand removing tools, but I still prefer scalpels
Edited by Jon
  • Thanks 2
Laser welded collets limit your sorting  the hairspring  with the balance attached, a pain.
If collet is removable detach the balance & hairspring. then;
On 8/13/2019 at 9:41 PM, JohnR725 said:
Good luck
When I first started manipulating hairsprings I wrecked plenty simply because I let my tweezers open too quickly.  My fix for this was to put a small elastic band (or similar ring that won't slip) around the tweezer and slide it towards the points to reduce the 'normally open' gap. Then if you let go too soon the tweezers will not open to a large gap and possibly wreck some coils.
I also keep a couple of tweezers just for hairsprings, having dressed them to be true and square.
Don't tackle if you are tired or time pressured.  Take a rest if you are getting annoyed with yourself !!
Sometimes on the bay you can get a cheap mixed pack of balance springs.  Whilst these may be in good shape, you can practice by creating your own damage and then repair it without any risk.  Your current problem could easily be replicated this way so you can the try to repair as practice before working on your movement.
PS I still  manage to wreck some.😁
Edited by canthus
9 hours ago, transporter said:
is it just me, but I cant see the actual hairspring pinned to the stud, also the balance isnt sitting in the jewel so its bound to be out of shape
yes one of the minor problems of having a balance wheel out of the watch is it's not necessarily in the same position as it would be in the watch. In other words in this case it's leaning slightly which is going to cause a minor problem. Which is why the final tweaks will have to be done in the watch or verified in the watch to make sure your successful as opposed to out of the watch it looks perfect.
I find laser welded collets will come off the staff given enough patience and flexing of the scalpels.
The trick is once the hairspring work has been completed to slightly close the collet hole up by about 0.15 mm with domed stakes top and bottom in an 'inverto' staking set before refitting, as there is no longer a weld and it was never friction fitted, so the friction has to be created. I use a smoothing broach to gauge how much I've closed up the hole with the staking set.
I posted on my Instagram (https://www.instagram.com/jonthewatch/) the second year students performing all these processes and they all nailed it. They started practicing with clock hairsprings which I showed in my earlier post, then scaled down in size to an ST36 spring (clone of ETA 6497) which is still a fairly large spring! Once you know what you're doing, I find it really relaxing work, as you a totally in the present moment. No thoughts of past or future, just there and then. Almost meditative.
    • Since I couldn't slow the machine down enough for my liking, I started off slowly with a higher grit.  I began (very lightly) with 1000 grit paper: https://www.amazon.com/gp/product/B07DTJBND1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Finished with 3000 grit: https://www.amazon.com/gp/product/B07DTFSMT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Afterwards I went on to polish with traditional methods using felt & cotton wheels, with different grades of Dialux. Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
    • Greetings from another electronics designer & programmer!   I suggest you get a batch of similar scrap movements from ebay - I found batches of Seikos very cheaply, I got seven of one type for £11 (or 11 Euros possibly?). Those were ladies, 4206B I believe. There are also mens movements at a slightly higher price; eg. https://www.ebay.co.uk/itm/134723051997 https://www.ebay.co.uk/itm/235565276549 They are cheap enough so it does not matter what gets messed up or lost & you can probably still get one or two working movements from a batch, even if some part are damaged when you get them. (I've had quite a bit from the guy in Holland, he usually has a good range of movements).
    • Please OH, we should all be proud of our collections what ever they are. If we can't show them off here then we can't show them anywhere. Our favourite gives us a story to tell of why we love it, that story also tells others something about ourselves. These are some of the things that make our forum and our community so amazing .
