Hello all.
Now approaching my mid 30's I've had a sudden love for knitted jumpers and trying to spend my time off work doing something positive. I have decided on giving watch tinkering ago. I am afraid I am a fan of Armani watches and I now own 2 that are not ticking and another that works but has a broken crystal. I have gone through the past threads and there is some great information regarding Armani's and how to get started. They seem to be a pedantic time piece, but I'm hoping any snags that might happen have hopefully already been explained and solved in past conversations . But if I get swamped I'd be very appreciative of any advice anyone could spare me. Many thanks!
Thankyou. I've bought myself some more tools and was expecting a pry bar kit from Amazon. This arrived this morning. It's not what I was expecting hah.PXL_20240329_141548101.thumb.jpg.3f2c0c19b42e6211d5d8ebc6160b332b.jpg
  • Sad 1
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
Did you order Chinese tools, because if you did you are not the only one that is sent total crap.
I think you were "forked" over.
I am afraid so. They sent out another set and let me keep the fork, which was very kind of them. But unsurprisingly the pry tools are far too thick to be used on watches without damaging them. I would be better of using the fork tbh. Oh well lesson learnt.
They got me again lads! Temu's finest. Fool me once shame on you, fool me twice and I'll just complain about it on a forum. I'm thinking good tools ain't cheap and cheap tools ain't good hah!
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
