I have just started on an Elliott mantel Westminster chime clock I picked up on Ebay. When I looked at the platform escapement, the balance wheel is very wobbly. Should this be or has something gone wrong? I am wondering if it is a broken balance staff (doesn't look broken though) or has the lower pivot hole worn? Or is the wobble normal?
Have included photos. Thanks in advance for your advice.20240302_172436.thumb.jpg.89b3df913c0e45e38b6852796a680adf.jpg20240302_172452.thumb.jpg.ae7727dac070fb1afa841f5de6118602.jpg20240302_172506.thumb.jpg.c9d84fdb9b64e9477363836998d60e2d.jpg20240302_172532.thumb.jpg.5e1b15b0f91ce2f4679502ccdb052295.jpg20240302_174113.thumb.jpg.3a9178aef84ce120a8b17106b0162118.jpg
Hi Richard. I've done my best to get photos. The first two are the lower pivot. The second two are the upper pivot but it's hard to see because of the spring.20240302_182427.thumb.jpg.476baf0d837fb13a0699ce67a7b214f1.jpg20240302_182420.thumb.jpg.8c13b8aba77cdbe559a5345257edcec0.jpg20240302_182132.thumb.jpg.b2d4d5f18dd5fdeccc5717da27ebee70.jpg20240302_182036.thumb.jpg.2d4e650e9df44e3bb20782107d025210.jpg
Here is a slightly better photo of the top pivot. It doesn't seem to have the very fine end that the lower one has.20240302_184217.thumb.jpg.2bb7f6219b79d86909be236a39da29e1.jpg
I think that's just a problem with the picture (maybe a relection or a speck of dust). I have had another close look and that pivot seems alright. Looking again at the upper one, I think that is where the damage is. Have never worked this closely on a balance before so need a lot of guidance. Not sure how to remove the spring. Thanks for your help this far Richard.
7 minutes ago, RichardHarris123 said:
You may have to unpin the hairspring to see the top pivot properly.
you do not have to unpin the hairspring but you do have to remove the balance wheel from the bridge which are going to have to do for cleaning purposes anyway. To remove the balance wheel there are two separate steps of getting it off the bridge.
first you need to loosen the hairspring stud screw. It's in the image below this will allow you to push the stud out but not yet and once it's out gently screw it back in again so doesn't fall out it's a pain to put them back in when they fall out
then you remove the balance bridge with wheel flip lid upside down because you need to release the hairspring between the regulator pin and boot. you can see a side view picture here of
understand better of how to free the hairspring up we can see a side view here notice I marked something that's basically a screwdriver slot. So with the bridge upside down you put a screwdriver in here gently turn 90° or just enough to free up the hairspring so I can slide out then you can gently flip the whole thing over and pushed the hairspring stud out and in the whole thing should be free of the balance bridge.
here's something that would help out in addition to the help from the group. a PDF on servicing platform escapement's
Servicing a Platform.pdf
  • Thanks 2
Thank you both. I am going to get a decent set of screwdrivers and a good magnifier before I go any further! Also going to be absolutely certain I know the names of the various parts so I don't get things mixed up.
Seeing a balance in a platform at that funny angle. I would say the staff is broken or jewels or both. To be sure a photo of the complete balance unscrewed for the balance cock and showing both balance pivots.
Had closer look by eye (cannot get the camera to the same angle) and I think it is the pivot at the top of the staff that is broken. Have ordered a set of very small screwdrivers and a headband magnifier with LED lights from Cousins, also some fine tweezers. When they come I will be able to remove the spring stud and have better access to the staff.
Will post a photo later this week.
20 hours ago, RichardHarris123 said:
Oops, sorry I meant remove the hairspring not unpin it.
You mean remove/ detach  the balance complete from the cock, not remove the hairspring.
So, you should dismantle the cock setting to check for possible  damage to the end stone caused by bad pivot end, also as John said to clean the jewels there.
My small screwdrivers arrived and I removed the balance wheel from the cock. It seems clear that while one of the pivots is intact, the other end has no pivot at all. I suspect this is not going to be a straightforward repair! What do you suggest? The first photo is of the good end of the staff. The next few are of the broken end.20240307_205221.thumb.jpg.41f8c61011bf282da0cc7da38bd733fb.jpg20240307_204631.thumb.jpg.4db5352107e22f20263a542af2de2020.jpg20240307_204545.thumb.jpg.59101ad23a28570fe76a67245bfaedc1.jpg20240307_204439.thumb.jpg.0a636b8babaeab51890f940c0b5d864a.jpg
Needs a new balance staff. The hairsprings needs sorting out as well. Are you able to make one? You could look on ebay. You could get i touch with this person.
Specialists in Elliott Clocks 14 Langdale Court Witney OX28 6FG
I thought that would be what was needed. I cannot make a new staff (haven't got a lathe for a start). I'll get in touch with the people you suggest, see if they will carry out the repair. Thanks
Thanks Mike. I've asked the people in Oxfordshire for a quote about the staff. I'll let you know how I get on.
The specialists in Witney only do whole clock restoration so it looks like I'll have to either find a new staff on ebay or make one. I Hope to join the horology classes in Epping in yhe autumn - maybe I'll wait until then and complete the repair under supervision (and with access to the proper tools).
I have seen this on Ebay (see link at the end of this post). It looks the same as mine except mine has a small section cut out of the platform, about 5mm square (see photo). This would mean transferring the good balance wheel to the existing platform. The vendor wants £85 plus postage. Does that seem reasonable?17100177983019199710772171965701.thumb.jpg.f50967b159e8cda8da122f6106dd1185.jpg
https://www.ebay.co.uk/itm/116095330187?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=aZDrGQg8SVq&sssrc=4429486&ssuid=vviqc_f1t1m&var=&widget_ver=artemis&media=COPY
Hi Rixy as it happens I have been going through a similar process with a Russian submarine clock. Been battered and the staff was broken at both ends. Managed to source a spare and although they will fit any Russian sub clock I swapped the balance into the other escapement , it fitted ok and spun up with the blower but when fitted to the clock , no go. So returned to the status quo . And worked out I could move the escape wheel pinion guard for it to fit it now works but more to do.   Although they look the same they might not be exact and be an expensive  £85 spare.  Iwould try to get the old one re staffed.  I have some staffs for my clock on their way with the intention of repairing the old one .   I mention this as a guide but the descision is one only you can make    All the best and good luck.
Is the replacement off an Elliot and are the dimensions the same and remember the drop of the escapement pinion as re gardens the mesh with the contrate wheel
Thanks WW, it is quite a pricey gamble. It is from an Elliott and looks like it should fit but if it doesn't I have an expensive spare part sitting in a drawer! I think I'll pack it away for now until I start the classes in September and see what they say there.
When it comes to replacing a platform. You need to know the size is the same, depth and length of the escape wheel  so it will mesh with the contrite wheel, how many teeth does the escape wheel have, are the holes on the platform in the same place for fixing. If you can get all these measurements from the seller and they are the same as what you have then go for it. It well certainly be cheaper then having a balance staff made.
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
