Fossil dual face watch battery replacement
Hi my name is Tom and I am new to the group.
Need help. I am trying to replace the battery in my Fossil Grant dual face watch, FS5123. I have tried several ways to separate the watch and nothing has worked. The black face seems to be the side that separates. Any help would be greatly appreciated.
Tom
Hi, welcome, you don't show the  back of the watch, I can't tell if its a screw-back or snap-back, from the picture it looks like a snap=back which would need to be separated by an opened that is different for screw-back.....surly someone on here has seen this watch  before...
Hi , the process as I remember involves in removing one of the stems. The rotary you remove the bezel and remove the stem and the watch lifts out so in effect you have two watches one on top of the other. Whether the tissot employs the same method I can’t be sure.
Hi. There are also some watches that have screws around the circumference, these are hollow with a slot and usually level with the surface. When these are removed the two cases pull apart. There can be up to four such screws I guess depending on the make,    That’s all I know about these type watches.
I have tried a knife blade, a screw movement single blade back remover and 4 blade screw movement bezel remover, nothing seems to work.
There are no screws on the sides of the watch. there are 2 pin and pin holes opposite each other on the side for the band as shown in the photo.
Hi sharp eyes @eccentric59 the slot is lost in the glare from the case. Most have pry off bezels some are attached with  four screws around the bezel and the rotary you remove the watch fron the case ( pivot screws) and lift our the movements  and then remove the case screws from the periphery and split the case but in almost every case the stem has to be removed once access is gained.
Hi @RichardHarris123 not necessarily, on the some the dial is in two parts. Once the bezel is removed the chapter ring is removed gaining access to the stem release, once done the top watch lifts off allowing both batteries to be changed. They all seem to employ the same method just achieved differently On others the bezel is removed by removing screw on the bezel , others use pry points. Its a case of careful inspection before proceeding.
    • Welcome! To which part of India will my greetings go? Frank
    • I agree with @Waggy, no need to adjust. That looks very good to me. The factory specs for 7S26 are something like -35 to +45s/day, but they are usually better. The amplitude is good. When wearing, the most important positions are dial up, crown down and crown left. You need to regulate so that these positions average out to about zero. Crown down is showing +14, so you may have to set dial up to slightly minus s/day. The absolute values of +/-s/day don't really matter, as long as they aren't too far out. The only way to get good accuracy is to wear it for a couple of days, recording the errors, and gradually tweaking.
    • @Jon The link is no longer working and I wanted to see that demonstration again. Is there any chance you can make it available again? I'd appreciate it!
    • Or, if you have a staking set or jewelling too, just use one of the stumps. You can choose a fine tip to fit inside a jewel if necessary.
    • Good morning,   To be honest, I'm not sure I trust my own logic anymore 😅. But here's a picture of my own (failed!) attempt to install a new rotor axle. I punched way to hard and even split the metal of the rotor. My thinking was that, in my case, the axle sits "deeper" in the rotor and hence the rotor would be closer to the movement plates. Vice versa, I was thinking that a very light punch could cause the rotor to sit rather high. But not sure that makes sense because in both cases, the flat part of the axle and the rotor align equally.     Sorry, but is he saying that the outside of the caseback has been polished to such an extent that the inside of the caseback has deformed/sunk??? That sounds crazy to me because those casebacks are thick! Can you see any signs of that on the inside of the caseback? Have you tried screwing in the caseback a litte bit more or less so that the supposedly "sunk" part of the caseback would move from 9 o'clock to e.g. 6/7 or 11/12 o'clock?  If the caseback is truly deformed, maybe it could be punched/pressed back into shape (e.g. with glass/caseback closing press).      I agree with your choice. But yea, Rolex makes it VERY hard for independent watchmakers to do a perfect job because we can't get (original) parts easily.      Your pictures aren't too bad. But still impossible to see if the rotor isn't perfectly flat. You'd have to look at it with your loupe, from the side (like the pictures), and turn the rotor to see if the gaps (with the automatic bridge plates) increase/decrease.     Finally... how is the up/down play of the rotor? To test, take a toothpick/pegwood and press on the small triangular side of the rotor next to the axle (NOT the big side where the weight is. But the opposite side.). Does that lift up the weight-side of the rotor? There can be some play, but it should really be minimal. If there's too much play, a new spring clip is the first thing to do. After that, one could play around with the jewels. This is too much:
