You know you're into repairing watches when...
I could only improve it, its still not perfect, the slight bit of wobble left seems to add to the agitation. -
Demagnetising of an anvil will depend of the anvil size. If it is big, then nither Elma, nor chinese clone will do the job. But the K&D from the picture will do. Have in mind that the bigger is the object, the stronger is the magnetic force that it will fill inside the field. If You can't hold the object still, then You will need demagnetiser that works on higher frequency rather than smaller one. -
Forgot to mention that only demagnetize a balance when its in the movement, otherwise the magnetic field will snatch the coils and damage them
Sometimes a sticky hairspring might unravel after using a demagnetizer. But if you push the coils until they touch, they will stick together again. I find that brushing the coils gently while submerged in naptha the most effective way to cure a sticky hairspring. Sometimes it requires 2 or 3 washes to cure it. I often wondered what causes a hairspring to become sticky. The 9010 in the jewels are unlikely to drip onto the hairspring. The other possibility is the 9415 on the pallets. But then that's on the other side, below the balance. Can it "splash" onto the hairspring? Looking at the stickiness and tenacity, I'm leaning towards 9415.
