Obligatory boring introduction
RayNeuman
Greetings! I am Ray. Retired to Green Bay Wi and for the most part a buttugly ol biker given a second chance. I have enjoyed horology for many years and have wanted to dabble in building watches for more then a few years now. Having the time on my hands, and the budget restrictions retirement brings, seems like a good time. Please know I am a complete open slate so whatever advise or direction you may have I would welcome. My first purchase will be a tool set.  I most likely will get a cheap ebay or Amazon set and regret it, but it seems a right of passage in most things. lol. My goal will be to build 2 distinct watches. One will be based on a ETA 2824 maybe a no-date. And the second will be a hand wind more dress watch. Of course, once again, my uneducated thoughts.
Thank you for allowing the rif raf in and I hope to be a worthy addition.
Ray,
Welcome to the addiction!
When you say "build 2 distinct watches" can you explain what you mean by that, for example do you mean buy an complete vintage ETA 2824 watch, then strip it down to the last screw and then rebuild it, or do you mean buy the major new/working parts i.e. movement/case/strap etc. and simply assemble it. This choice will have a big impact on what tools and knowledge you need. If you let us know, the floodgates of advice will open I am sure 🙂
Ray
Welcome from across the pond. Tool set, regret? No such thing. I have been using my £13.50p set I purchased 23 month ago. Still using all the tools at some time. I make sure my screwdrivers and tweezers are always dressed (filed).
I was less than at your state then. Apart from owning a watch I had never done anything other than wind. Really did start from scratch.
I've listened, been advised, cajoled by the wonderful members of this forum. Many are experts, some professional. All have taken the time to offer help and assistance. Can't fault them.
Two pieces of advice I offer. Do a distance course. Practice, practice, practice and then, practice some more.
Can't fault this hobby either.
Ray - you are already ahead of me, as I registered and joined Mark's course only this evening.
I hope you enjoy the journey as much as I look forward to.
My background is in soldering and making little electronic circuits as a hobby, so I'm hoping some techniques are in a way transferrable (dealing with small bits and making sure they don't fly off).
On with the adventure!
Trystan (Manchester, United Kingdom)
I dont have the skills to rebuild a movement........yet.  I want to get a working 2824, select the case, dial hands and face to put it all together.  I am sure its a pretty simple procedure for the likes of this group, but my skill set so far is blowing a mean blues harp!  The short version- I used to work on Harley's and play 11 string instruments. Proficient  in martial arts and could be found on a stream side with a fly rod most days off. Then.......open heart rebuild. It took about 80% of my right arm, neck and hand. (yeah, they messed up) so now I have to approch everything with extreme caution in both physical and budget. So ANY direction (and ways to save a buck) is very welcome!
For my former biker friend, you are going to hate my russian cranky old gal!
RayO-LIViaBackPatioFarView(2019_09_1322_51_04UTC).thumb.jpg.5bcbf283ad8d49ef2828ca90b38fbafb.jpg
Ray,
Well putting together a watch is quite straightforward. You get your movement, iso for you a 2824. Then you look for a face for that movement that you like, likewise with hands. Then select a case for that movement and at the right size for the face. Then buy a few winding stems.
Put the face on, put on the hands. Put the movement in the case. You cut the winding stem to the right length so that when you push the crown in, it goes in the correct amount. The you put the crown (that probably came with the case) onto that stem, with a bit of threadlock. Then you put the back on the watch, put a strap on it.
Then sit back and admire your work.
I've done just that with a Seiko 5, putting in a different movement (NH36) to what it came with. It now handwinds, hacks and I've regulated it to around +4 s/day. The biggest difficulty I found was cutting the winding stem to the correct length. Oh, and putting on the second hand was really tricky! Have a go. It's very achievable and incredibly rewarding.
So this course is my next step.
Trystan
Thank you all for the great advise. I am going to start picking up a piece here and there perhaps one each month. I once was given a very expensive "grail" watch. Wore it for 5 years and discovered a problem with it. Initial estimates were $1000-2000 for general service and small repair. I could never afford that and I could not see it setting in the drawer so sold it and got a very nice Seiko solar GMT. But I do love auto movements. Going this route would be somewhat affordable to me and sounds like it would be interesting as well. I have a great deal of respect for the NH34 styles of movement and the thought that if it goes south, $50 and a couple hours I can get it back running!
If you want to build an ETA (real one), I can recommend this eBay seller. No affiliation other than I have bought and built with their parts at a friend’s request.
https://www.ebay.co.uk/str/swissmadetime?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=hL35BJNHR7W&sssrc=3418065&ssuid=suvalalxrs6&widget_ver=artemis&media=COPY
pricey but Swiss 🤷‍♂️
Tom
Hello Ray,
i am from Switzerland and the above mentioned eBay seller is more than ok. i bought many Movements and other Parts from them.
But, if it has to be a Swiss Movement, i would buy a Selitta from them ( i have 2 x SW200 and 1 x SW220 from them).
for the start i would suggest to buy Seagull Movements from Aliexpress or eBay, the ST2130 is equivalent to the ETA2824-2 and Selitta SW200, i pay about $58 for a ST2130, but for a SW200 or ETA2824-2 you pay between $200 and $300 depending on the Quality Grade (Standard / elabore / Top / Chrono )
hope this helps
Ernst
(And yes, many Years ago i was a Biker too, but different Bikes than yours)
    • Correct one dip is expensive when the chemical is purchased as " one dip " which is why it is mostly reserved for these two small parts as far as information tells us it is mostly tetrachloroethylene. I use it bought as perchloroethyl used in dry cleaning processes, i cant say I'm overimpressed with it though it appears to me to be shellac safe. What may be a better solution for hairsprings is a high lab grade of pure benzine.  IPA is mostly used as a rinse and water displacer and yes it does have the potential to dissolve shellac, personally i would not buy anything that has significant water dilution so 99.9% IPA is the way to go. And lastly the part you are cleaning dictates your choice of cleaning brush, delicate parts like a hairspring requires the finest artist's brush you can find. Plates and bridges can take a little more scrubbing, but always check to make sure the surface is being unharmed. And dont forget a stick of tip benzine soaked correctly shaped pegwood is your mate set up for cleaning dirty jewels and removing stubborn dried up lubrication.
    • Den / Dennison is a unit measurement of size this is actually a mainspring gauge . I haven't heard of a pivot been measured in Dennison before.  Though the small thickness gauge is  usually supplied with a Jacot tool and is more accurately known as a pivot destroyer.
    • Could it be an abbreviation for Denier? "Denier (/ˈdɛniər/) or den (abbreviated D), a unit of measure for the linear mass density of fibers, is the mass in grams per 9,000 metres of the fiber. The denier is based on a natural reference: a single strand of silk is approximately one denier; a 9,000-metre strand of silk weighs about one gram." The pivot gauge looks interesting, however I wouldn't trust myself to drive a pivot into a wedge incase it jams and gets damaged/snaps trying to get it free. More a comment on my ability and incompetence than the quality or design of the tool 🤣
    • As I've seen multiple posts here about multiple types of cleaning solvents, I've done little more than confuse myself more thoroughly that I was before. To see if I understand things correctly... 1.  Is One dip is a solvent which is a cleaner and also a protective rinse for hairsprings jewels and pallet stones only? Or can it be used on all the parts (like the case and wheels and all the things) It seems like that would be much easier as it's just "one dip" but it is very expensive. 2. Isopropyl alcohol is a great cleaner for manual cleaning or ultrasonic cleaning (only enclosed jar) just not on pallet fork as it may loosen the shellac holding the stones. Does it have to be 99%? 3. When buying a small manual cleaning brushes, does anybody suggest a certain material of the brush itself?
