Stubborn back removal?
🤔 the crystal doesn't have to fit onto a detachable bezel, it can be pressed into the front of the case. Very curious as to why there is a threaded ring inside though. I do have a record www that i could pull the movement out of but I'm away in just over an hour. -
If the parts from China cost 5 cents and someone in Switzerland gets paid 6 cents for putting it together it can be called Swiss Made, right?
Maybe you should make friends with someone who has a 3D printer
By Michael1962 · Posted
If the front of the case has no bezel and has an internal diameter less than the outside diameter of the lock ring, there is only one way that the crystal comes out and that is from the back. You could always smash it and take it out the front. I’m here to help. 😉 Take a photo of the crystal side of the case. -
I have no idea ? I'm new to this. But, there is definitely a locking ring at the rear of the crystal and no detachable bezel on the front of case ? So, I am guessing you need to back off that ring ? There must be someone on the forum that has restored one of these ?
